Need Help! Spindle dead?
Results 1 to 4 of 4
Thread: Spindle dead?
    Nov 2017
    Brunei Darussalam
    Default Spindle dead?
    Hi guys. Im a newbie to all these. I got myself a chinese CNC 3040Z-DQ machine. Assembled the machine and everything works fine. Learned how to draw 3D objects and creating tool paths. When I tried the first engraving, 1 of the gcode was wrong and lead to the spindle plunge all the way down. Jammed then stopped. I stopped the Mach3 right away. Removed the drill bit from the wood and the spindle wont run again. X Y Z still works controlled by my laptop. Just the spindle doesnt workor spins anymore. Checked the cables connects to the spindle with a DC voltage of only 0.4 Vdc. The controller machine is on and connected to mach3. I disassembled the spindle and everything seemed fine in the inside. Anyone can shed me some lights whether its the spindle or the controller having problem? Or where should I check inorder to know what should I get for replacement or get it repaired?
    Thanks in advance!
    Attached Thumbnails Attached Thumbnails Spindle dead?-imag0381-jpg   Spindle dead?-imag0380-jpg
    Member john-100's Avatar
    Mar 2007
    uk
    Default Re: Spindle dead?
    if your control box is like the one in this post :-
    http://www.cnczone.com/forums/chines...oc-pw3024.html
    you will see from the circuit diagram in the post there is two fuses
    one for the stepper driver DC supply & one for the speed control
    Spindle dead?-yoc-3024pw_diagram-jpg
    Spindle dead?-yoc-pw3024-layout-jpg
    if your very lucky you may of blown fuse F2 that powers the spindle motor
    check resistors R 3 & R4 have not been burnt by the overload
    Spindle dead?-yoc-pw3024-note-check-r-3-4-a
    John
    Nov 2017
    Brunei Darussalam
    Thanks John! Will open up the controller and have a look later. Fingers crossed.
    Quote Originally Posted by john-100 View Post
    John
    Nov 2017
    Brunei Darussalam
    I can really grab and kiss you John! Its a broken fuse XD Thank you so much. Initially was thinking this machine is down the drain. Thank you once again.
    Attached Thumbnails Attached Thumbnails Spindle dead?-imag0382-jpg
Spindle dead?
Spindle dead?
