Decrease your Z axis acceleration by 25%-50%, and see if that helps.
How much is it out of position?
Hi
Im having a issue where when i zero my z and start to cut after about 10 mins in the cut the z axis has moved higher than when it was originally zeroed.
can anyone point me in the right direction on how to trouble shoot this?
UCCNC 2017 Screenset
I have tried reducing acceleration and it still does it.
Ive removed the spindle and ran the code without that attached and it still lifts.
I zero it run the job for one minute and then go back to zero and the high of the z has moved up.
Not sure what else to try any suggestions?
Did you try to change steps per unit? Does the spindle goes as high or as low you say to go?
Sent from my HTC Desire 620G dual sim using Tapatalk
Does the machine have gas struts or pneumatic cylinder to assist the z axis against gravity?
With power not going to the z axis motor, can you move the axis by turning the ballscrew? Is it difficult?
Could be alignment issues, could be linear bearings issue etc.
I've sorted this now.
I swapped the stepper motors around and stepper drivers but I noted on aspire I was performing a pocket but using a profile tool path instead of a pocket. but which ever of the above seemed to fix the issue.
Sent from my SM-N910F using Tapatalk
