Sorry, I have never seen this and can't even find it on eBay. Did you try to contact the seller?
Hi everybody,
do you know this breakout card
I built a probe ... but I do not
clear how to physically connect it internally
to the USB controller. I did a lot of research without
find the solution. I cannot find the installation manual.
This is the image of
card that I find into the Controller PRT-E750.
Many thanks in advance
Walterius
motion controller card 4 axis
model bitsensor BSMCI14C
https://www.youtube.com/c/AdaptingCamera/videos
https://adapting-camera.blogspot.com
Just a word of warning: many Chinese controllers cannot handle a probe input. This drives people crazy.
I have no idea whether yours can or cannot.
Cheers
Roger
thanks..
can be a big problem!
yes, that's the first thing I tried, but no answer.
I just have to hope someone can tell me a track
to follow to understand the details of this card ...
Is this a Mach3 card?
UCCNC 2017 Screenset
Hi Walterius, just came across your post, a couple of years old, I have the red card (basically the same as yours) and have some manuals BUT they are in chinese in .pdf.
I had started to translate some of them but lost them due to a crash. The text in a pdf can be copied and pasted into Google translate, the English can then be repasted back into the pdf replacing the Chinese.
If you do not have the manuals, yet, and are willing to go through this laborious process, I can send you the pdf's or I can post them here.
I would assume you inserted the .dll file to tell Mach3 that there is a usb card attached, mine is way better than the printer port card.
Regards
Eric
Hi Walterious
Have you able to setup the breakout card? I have bought same one and trying to setup, It's done to me
I do not know how to setup it in mach 3, to control my VDF via the board
I found manual but in Chinese language, it not easy to understand with google translation
Any one have been used this, please advise
Huan
