If the axis is straight and the angle between the x and y axis is not 90 degrees you will get parallelograms. Parallelogram angle should not increase or decrease depending on its size.
If the angle does changes, meaning one parallelogram is 89 degrees and the other 87, probably the sliding bars are crooked. If the sliding bars are not straight, you won't get straight lines either. I expect that two different locations on your table will yield two different shapes.
I hope your angle is always the same...
Sent from my Nexus 5X using Tapatalk
