Hi.
I bought an SD 6090 which is a reasonable machine - I had experience on two before I bought - but I have found that the X and Y axes do not cut at 90deg to each other .
As far as I can measure the difference is just less than 1 deg.
Could this be a software artefact? (They recommend U CanCam but I have been using a post processor from above)
If it is an alignment issue how do I adjust it? It is a very solid machine. Photo attached...
Thanks,
Rob.
