All,
I am looking to build a 1212 / 1313 machine (seems like for most vendors you need to go up to 1313 to get the beefier setups).
This is for Hobby / Small business use and is primarily for cutting hard woods.
I am looking for advice on the machines, manufacturers and/or components.
OMNI1313 Quick KT30MT RochTech ROCS1313 ELE 1313
Work Area 1300mm x 1300mm x 200mm 1200mm x 1200mm x 200mm 1300mm x 1300mm x 200mm 1300mm x 1300mm x 200mm
Spindle 3.0kw HQD water cooled 3.0kw water cooled 3.0kw HSD air cooling spindle 3kw Changsheng water cooling
spindle,ER20,24000RPM
Driver Motor Yako Drive and Stepper Motor Stepper Fuling 118 Stepper Motors and Yako 2811 driver stepper motor and driver
Table Size 1300mm x 1840mm 1350mm x 1350mm
Machine Size 1700mm x 1840mm x 1700mm 1850mm x 3150mm
Frame Thickness 6mm Welded Structure Heavy Duty Machine Body
Inverter Taiwan Delta Frequency Inverter Fuling Frequency Inverter 3.7kw Delta Inverter 3.7kw fuling inverter
Spindle Protection Device Temperature Montiroing Device
Machine Table Bakelite combined Aluminum T-slot extrusion Vacuum and T-Slot Combined T-slot & vacuum work table,4 zones
X, Y, Z Travelling Potioning Accuracy ±0.05mm 0.025mm ±0.03mm/300mm
X, Y, Z Travelling Repositioning Accuracy ±0.05mm ±0.03mm
X,Y,Z driving system Helical Rack and Pinion (x/y), German Ball Screw (z) Helical Rack and Pinion (x/y), German TBI Ball Screw (z) Rack and Pinion,(x,y), Ball Screw (z) Helical rack-gear transmission for X,Y axis. Taiwan TBI ball screw for Z
X,Y,Z bearing rail guide system Hiwin square rail linear baring 20mm Tiawan Linear rail 20mm Hiwin square rail linear baring 20mm Sweden SKF Group international advanced self-lubricant linear guide --- ABBA #20
Max Rapid Travel Rate 32,000mm/min 35,000mm/min 33,000mm/min 12,000mm/min
Max working speed 20,000mm/min 25,000mm/min 25,000mm/min 10,000mm/min
Working voltage AC 220V/60Hz/ 1 phase AC 220V/60Hz/ 1 phase AC 220V/60Hz/ 1 phase
Command languages G code G code G code
Control system MACH3 Controller with wireless handle DSP A11 System MACH3 Controller with wireless handle MACH3 Controller with wireless handle
Software Ucancam English version Artcam Software
Limit stop Extra-travel limit stop and hard limit stop
Gross weight 1250KG 1050kg 1300KG
Free Parts Cutting Tools (20)
Woodworking Bits (10)
Collet (4)
ER Collet (1)
Clamp (8)
Water Cooling Pump (1)
Spanner (2)
Brush (1)
Power Cord (1)
USB Cable (1)
Manual Oil Lubrication
Manual Lubrication system Lublication System
Cutting Tools (10)
1 Tool Box 1
2 Woodworking Knife 21 Different size
3 Collect 3.175~20 4
4 spanner 4
5 fuse core 2
6Clamps 8
7 CD with software and manual 1
8 Adjustment screw 4
Dust Collector YES (includes dust shoe and 5m of hose) Included Included (smaller)
Vacuum Pump/Table Included Included Included Included
Vacuum Zones 4 4 4 4
