Problem Pulse equivalent CNC ROUTER WDG6090
Results 1 to 2 of 2
Thread: Pulse equivalent CNC ROUTER WDG6090
    Feb 2013
    israel
    Default Pulse equivalent CNC ROUTER WDG6090
    Hello,
    I'm looking for the right pulse equivalent for CNC ROUTER WDG6090 or a formula to calculate it.
    Thank you.
    Jul 2017
    Default Re: Pulse equivalent CNC ROUTER WDG6090
    Formula of calculating pulse equivalent:
    The right X axis motor's pulse=the expected X axis cutting size /the reality X axis cutting size*existing X axis motor's pulse
    The right Y axis motor's pulse=the expected Y axis cutting size /the reality Y axis cutting size*existing Y axis motor's pulse
    The right Z axis motor's pulse=the expected Z axis cutting size /the reality Z axis cutting size*existing Z axis motor's pulse
    If cutting dimensions are different from what you want, just open "Operating"<"Setting parameters"<Select "Manufacturer's parameters"<Input password(original password is "ncstudio")<"axis parameter", find existing "axis motor's pulse and calculate the right axis motor's pulse according to above formula.
    Original: How to set right pulse equivalent for CNC router
    - - - Updated - - -
