Just In 6040 CnC Manual 220v-380v translated to English
Results 1 to 6 of 6
Thread: 6040 CnC Manual 220v-380v translated to English
    Jun 2017
    Default 6040 CnC Manual 220v-380v translated to English
    Hi Everyone, This is the Model CNC 6040 220v-380v PRT-E1500W controller VFD Manual translated to English,
    Its the best I can do without redoing the entire manual.
    Good luck
    ENJOY
    CHIMERA1960
    Attached Thumbnails Attached Thumbnails 6040 CnC Manual 220v-380v translated to English-vfd-english-manual-zh-cn-en-pdf
    Jun 2017
    Quote Originally Posted by CHIMERA1960 View Post
    Good luck
    ENJOY
    CHIMERA1960
    Hi Everyone, I just wanted to add this manual also applies to the 110v version 6040 cnc machine, so you can use these VFD settings to setup your spindle motor. Also use the rpm display on your panel to show actual spindle rpm, because all cutting speeds are formulated for rpms anyway so you can set the correct speed of the spindle for the material.
    I hope this helps take care later CHIMERA1960
    CHIMERA1960
    Member Tak67's Avatar
    Oct 2020
    Default Re: 6040 CnC Manual 220v-380v translated to English
    6040 cnc PRT-E1500W vfd settings.
    Hi all, I have Connected everything like it should installed Mach3 and put on the CNC openend the Mach3 software it says driver loaded but nothing works or responds.
    I did set the config as it should (double checked), still nothing.........
    No drivers cd or Manual was given, took a lot of searching the internet too find anything like plugins but non worked for me.
    Can someoone please help me i really want too enjoy my CNC. ( USB ) CNCEST PRT-E1500W
    HERE MY VIDEO wish get some help.
    - - - Updated - - -
    https://www.youtube.com/watch?v=9F74wMPTkWM
    Oct 2020
    CAN YOU HELP ME WHY MY CNC MACHINE NEVER MOVE?
    Member cncmakers001's Avatar
    Jul 2011
    China
    Good luck
    ENJOY
    CHIMERA1960
    Thank you for sharing.
    http://cncmakers.com/cnc/controllers/CNC_Controller_System/CNC_Retrofit_Package.html
    Jul 2012
    UK
    Good luck
    ENJOY
    CHIMERA1960
    Thank you!
