Need Help! New 6040 Machine with issues
Results 1 to 3 of 3
Thread: New 6040 Machine with issues
    Jun 2017
    Saint Lucia
    Default New 6040 Machine with issues
    We have a new 6040 machine.
    We have 3 issues preventing us from operating.
    First, I cannot change any parameters in the controller without getting the error code E030.
    Second, I do not know how to use the height sensor. I have it plugged in but do not know where the alligator clip goes.
    Third, the spindle does not rotate. when a command is sent to start engraving however the image outline is being traced by the XYZ axis
    Please help me to keep my job and let me know what's going wrong.
    Carl
    Sep 2005
    Default Re: New 6040 Machine with issues
    Carl
    Cant help you with the VFD really but as for the height sensor the alligator clip is put on the tool in the spindle. I think you may need a script to assign to the auto tool touch off button in Mach3 to be able to use it.
    The spindle has to be operated manually from the control box. Most 6040 to my knowledge are not set to run from g-code, so you have to start and stop from the vfd itself as well as adjust the speed. There are a couple topics in this forum about making it work with wach3, but I have spent 40 plus hours trying to get mine to work and have been unsuccesful.
    Hope that helps you some and hopefully someone smarter than me can help you further!!
    Walt
    Jun 2017
    Saint Lucia
    Thanks Walt good info to have.
    Carl
