Originally Posted by
moparx12
Thanks Russ... Going home now to try this. I have an aluminum yard stick (straight edge) I will use to dial steps per unit in at about 35 inches. I have seen some youtube videos where people use an engraving bit to better see where the spindle is so i will try that too. I will reprogram using the new bit diameter and cut a new test. What had me confused and still does, is that the amount that the parts are off is not consistent (on the x axis). Edges are parallel but too far apart!
