What Amperge?
Results 1 to 5 of 5
Thread: What Amperge?
    Member Tomcat104's Avatar
    Mar 2017
    Default What Amperge?
    Hey guys'
    Have an electrician wiring my workshop for a X8-1500M. Electrician just called and wanted to know the amps of the 240volt circuit. Thought I'd just look it up on their website and found...not a thing, notta!
    What are you guys using? Any idea of the actual amperage?
    Thanks in advance.
    David
    Aug 2015
    Default Re: What Amperge?
    I think u dont need more than 15 amps , and that is with vacuum and all u need for the garage .
    My cnc doesnt consume more than 350 400w when make an gcode .
    When i use vaccum , there is about 1300w pet total.
    At 15 amps u are at more than 3000w .
    Member KH0UJ's Avatar
    Jul 2016
    Philippines
    Well a 60 watt average CNC machine does`nt require a circuit breaker, we have 4 units of CNC machines working simultaneously and the power meter readings are just 240-280W, an ordinary 1/2 HP (2 pole) 3600 RPM bench grinder powered ON had a bigger watt readings (400-500W) compared to the 4 CNC`s working together.
    Member ger21's Avatar
    Mar 2003
    Shelby Township
    I'd agree with the 15 amps @ 240V. Probably less.
    UCCNC 2017 Screenset
    Dec 2003
    If running a new 240v line I would opt for 20amp Minimum, the cost difference is not that much, and you never know if you need something else for 240v down the road.
What Amperge?
What Amperge?
