Stepper Motor Temperature
Results 1 to 16 of 16
Thread: Stepper Motor Temperature
    Oct 2003
    Default Stepper Motor Temperature
    Hi all,
    Been a longish time since I posted here as a lot of "real life" things got in the way, anyhows, to my question.......:
    At work, we've recently purchased a 6040 CNC off Ebay (Australia), converted to Gecko drivers, etc., and have started to get my head around Mach 3 which was already on a PC that powered a 6040 we had a few years ago. Yesterday I went through the testing of the steppers which was all OK, today I turned everything on for more "playing" but spent most of the time reading the Mach 3 manual and investigating where to mount limit switches.......I happened to put my hand on one of the motors and found it to be quite hot even though it hadn't been actually operating..........IS THIS NORMAL?
    Any comments will be appreciated.
    Jun 2010
    Default Re: Stepper Motor Temperature
    You are putting power into the stepper motor even when it is stationary. So yes, it will get warm.
    If you are using a Gecko driver, you should be able to drop the max current a bit, at least for an experiment.
    Cheers
    Roger
    Member john-100's Avatar
    Mar 2007
    uk
    depending on which manufactures data sheet you look at
    stepper motors run at 70 to 80 degrees Centigrade = 158 to 176 Fahrenheit , too hot to touch !!!
    that's why many stepper drivers reduce the motor current when the axis has been idle for a short while
    if you use a G540 to drive 3.5A motors don't leave the 3K5 resistors out
    even though the G540 default current is 3.5A , the idle current reduction only works
    with the resistor fitted !
    John
    Member coherent's Avatar
    Apr 2003
    Arizona, USA
    As John-100 stated. the G540 will not go into current standby mode without the resistors, This will definitely result in increased motor heating.
    Jun 2010
    Yes - fit those resistors!
    Cheers
    Roger
    Oct 2003
    Thanks Guys,
    I'm using the Homann breakout boards with the trim pot and have set the current to 3.0A maximium.
    I'll check the temp with a point and shoot thermometer, I suspect they were at approx., 60 deg C.
    Cheers,
    Chris (in Newcastle)
  7. #7
    Jun 2010
    60 C - that's too hot.
    Cheers
    Roger
  8. #8
    Oct 2003
    Thanks Roger,
    I rechecked everything.......the motors are 3.0A and I remembered setting the current to 2.7A on the breakout board trim pots, the temp is sitting at 61 deg C.
    Will the trim pots on the G540 have any bearing on this as I haven't touched them yet.
    Cheers
  9. #9
    Jun 2010
    Ah - I don't know what BoBs you are using. The Homann BoBs I use (MB-02) do not have any pots. Regardless, I don't think they have anything to do with the current limit in the motor driver we are talking about. You need to put in the current limiting resistors on the G540 board. IF they are not there the motors will be driven at full power all the time, and that is why they will get hot. Put the right current limit resistors into the G540 board and they will cause the drive current to drop when the motor is static.
    Cheers
    Roger
  10. #10
    Mar 2007
    uk
    to me motors running at 61 deg C is not too hot for the motors but is too hot to hold your hand on it
    I think every one is suprised by how hot they run
    this is the Homann motor cable breakout boards with adjustable current setting resistors
    Stepper Motor Temperature-gc-02gc-02-db-9-stepper-breakout
    not to be confused with the breakout boards used to connect to the printer ports 17 input / output signals
    John
    PS
    I first become aware how hot stepper motors are , was when working on this sony betacart BVC-10 -
    Stepper Motor Temperature-sony-betacart-jpg
    its robotic tape player that was designed the 1980's to play out TV commercials
    it can play 10 second clips from 40 tapes in what ever order you program it
    the first 4 tapes are loaded into the 4 VT machines
    before the end of the 40 seconds the first tape has been ejected and replaced by 5th tape and is ready to play
    There is a vertical column between the vt machines and the 40 tape bins
    on the column runs an elevator that transports the tapes between the VT machines and the tape bins
    the elevator is rapidly moved up and down by a size 42 stepper motor
    (if I remember the motor size correctly)
    Stepper Motor Temperature-betacart-open-showing-elevator-jpg
  11. #11
    Jun 2010
    Goes to show what I know.
    I had forgotten about those DB9 things.
    Ah well - perhaps turn down the current a bit more - keep going until the system starts to lose steps, then increase a bit?
    Cheers
    Roger
  12. #12
    Oct 2003
    Aaaahhhh tape.......here at home I have a "studio" and my favourite recording medium is our 1" 16 track R2R, the 16 track digital is good but just doesn't have the same mojo but back to cnc......your comments are appreciated, many thanks.
  13. #13
    Mar 2007
    uk
    for the G540 , the current set resistor in ohms = current in Amps x 1000
    If you have work with a limited range of resistors you can use resistors either in parallel or series to get inbetween values
    for example the E12 range is limited to 10 , 12 , 15 , 18 , 22 , 27 , 33 , 39 , 47 , 56 , 68 , 82
    Multiply or divide the values by 10 for other decades
    Stepper Motor Temperature-g540-resistors-series-parallel-plus-gc-02-a
    plus my guess at what the Homann GC02 will be
    John
  14. #14
    Jul 2014
    Hello
    I have a big laser machine 1600m x axis
    and iam doing engraving so X axis can work continuously for 3+ hours..
    Machine has in X axis 573s15 3 phase steppers.
    Yesterday after 1.5hours of operation stepper in X axis stalled in the middle and not rotated.
    Mechanically the machine is ok the ways are ok.
    What can be the problem for loose steps ?
    Very high temperature in X axis motor can be the cause for loose steps ?(the x axis motor gets pretty hot)
    Iam asking that because the machine loose steps after 1.5 hours of operation not from start.
    The load all the time is the the same because laser head moves in the air.
  15. #15
    Member Sterob's Avatar
    Jan 2007
    Got a way of measuring the temp of the steppers? That might give a clue.
    Also, is the current limiting for your particular steppers set correctly? If it is set too high, that will probably cause the overheating.
  16. #16
    The motor temp can be as high as 70-80 C. For the G540, you need to use resistors to set the current as motor specification
    you need to have the right power supply too. We designed a stepper Motor at 3.5A,
    https://www.automationtechnologiesin...23h2100-35-4a/
