JST XH connectors
You can buy strips of pins and then housings with the correct number of pins, or you can buy pre-made cables. Cheap as chips on eBay.
For example the 4 pin jumper from the YooCNC interface board to the stepper motor driver for pulse/direction?
Trying to swap out the driver board for another brand. Thought there would be a better way than cutting all the existing cables, in case it didn't work out and I decided to go back to the OEM one...
Thanks for any suggestion. I've searched catalogs, but there are a lot of connectors in the world.
JST XH connectors
Thanks!! Will search that
QUOTE=dharmic;2030640]JST XH connectors
You can buy strips of pins and then housings with the correct number of pins, or you can buy pre-made cables. Cheap as chips on eBay.[/QUOTE]
Sorry, not certain about that one - but it does look a lot like a standard PC peripheral power connector.
