Looking for assistance with... :PARTIALLY SOLVED! - Page 3
Page 3 of 4 FirstFirst 1234 LastLast
Results 25 to 36 of 42
Thread: Looking for assistance with... :PARTIALLY SOLVED!
  1. #25
    Dec 2016
    Default Re: Looking for assistance with...
    The only thing not working is the Y axis. It tries then i use the manual mode from the pc, both Y+ and Y- make the motor whine, but nothing happens. again though, i can turn it by hand rather easily when the machine is off. What would cause this? I think the pins are correct
  2. #26
    Dec 2016
    Thank you John. The only number i have found for it is TX14175 but that comes back blank. I think that layout you did up will work nciely. Now i juust got to find a way to connect the wires to those pins. No idea what the connector is called.
    Quote Originally Posted by john-100 View Post
    so far a web search failed to find your breakout board
    using photos posted
    N/C limit switch connections to breakout board
    Attachment 354564
    john
  3. #27
    Dec 2016
    New evelopment. Now the spindle wont work. If oi try to turn it onm in mach3 it tells me that the PWM minimum has been bumped. I have no idea what this means. I had not changed anything before it started doing it
  4. #28
    Registered john-100's Avatar
    Mar 2007
    uk
    good to see your making progress
    I have had a quick look at connectors from Mouser
    this could be the connector you need for your limit switches
    Looking for assistance with... :PARTIALLY SOLVED!-mouser-part-number-571-440129-5-jpg
    440129-5 TE Connectivity | Mouser United Kingdom
    if thats correct , the PCB plug on the breakout board wiil be this one
    Looking for assistance with... :PARTIALLY SOLVED!-pcb-plug-jpg
    2.0mm,HDR,5pos,Vertical: 440054-5 HPI | TE Connectivity
    John
  5. #29
    Dec 2016
    Well i kinda made progress. one step foward, 2 back. Cant seem to figure out current problems. Y wont move, although its trying.. And spindle action triggers a "pwm bumped into minimum" error..
  6. #30
    Dec 2016
    Update: I got the Y axis working..ish... But it is odd. lets say i press up 3 times, 2 of those times it will go - and one tim e it MIGHT go +, seems random. Other times it will stay still and make a grinding noise. I am clueless here. Anyone got any ideas?
  7. #31
    Registered KH0UJ's Avatar
    Jul 2016
    Philippines
    I got your point sir, it just makes a hum noise while press a Y button, been there hehe, im going to work now then Ill take all the config files, screenshots on how I set my CNC on the ports and pins etc. I`ll get back to you after 5:00pm
    For some reason I cant PM you because your inbox is full, so I just post it here anyway
  8. #32
    Dec 2016
    I went ahead and cleared it out, can only have 8 pm's at a time! hahah
  9. #33
    Feb 2017
    I may be late to the party but did you look on the disk provided if there is a setup file? I don't have your machine, I have the 3020 but with my software CD I had a folder with different machine names on it. Inside was a file that when double clicked would configure the Mach3 software to set up the XYZ ports, motor speeds and also the STOP button. See if you have a folder like that, it might fix all your problems.
  10. #34
    Dec 2016
    Unfortunetly mine did not come with a config file. But as an updatew, it has been determined after using 2 different wires, on 2 different computers, that my breakout board is dead. I am having them ship me a replacement.
  11. #35
    Dec 2016
    eUpdate: Got a new VFD, i have no communication between the VFD and the pc. i am wondering if i need some sort of driver? Has anyone of you gotten on of these machines and actualy gotten it to work? I am still looking for help with this.
  12. #36
    Dec 2016
    Default Re: Looking for assistance with... PARTIALLY SOLVED!
    I have it working! ..mostly. User KH0UJ has taken a large amount of his time out of quite a few of his days to talk to me over google hangouts and help me to get it working. Without his help i would not have been able to get this machine to even make a noise. The X, Y, Z, and A are working very well, they jog at a nice speed. I have not optimized it to move at a very fast speed yet, but he taught me how to get them going and calibrated. The guy taught me WAY more about CNC and mach3 than i knew before. That all being said.. The man needs some kind of award for having to deal with me! haha.
    I will be making a post right after this to go over my only remaining problem.
