Here are some more pictures!
Imgur: The most awesome images on the Internet
The nicest feature on this machine is the fourth axis mechanism, I can make a thread on steel tubes exactly the same output on the lathe machine, it can make a 3D product out of steel, aluminum, wood, plastic, I can even make a whole 1911 gun on this CNC using just a 1/8 carbide bit hehe
The only thing not working is the Y axis. It tries then i use the manual mode from the pc, both Y+ and Y- make the motor whine, but nothing happens. again though, i can turn it by hand rather easily when the machine is off. What would cause this? I think the pins are correct
New evelopment. Now the spindle wont work. If oi try to turn it onm in mach3 it tells me that the PWM minimum has been bumped. I have no idea what this means. I had not changed anything before it started doing it
good to see your making progress
I have had a quick look at connectors from Mouser
this could be the connector you need for your limit switches
440129-5 TE Connectivity | Mouser United Kingdom
if thats correct , the PCB plug on the breakout board wiil be this one
2.0mm,HDR,5pos,Vertical: 440054-5 HPI | TE Connectivity
John
Well i kinda made progress. one step foward, 2 back. Cant seem to figure out current problems. Y wont move, although its trying.. And spindle action triggers a "pwm bumped into minimum" error..
Update: I got the Y axis working..ish... But it is odd. lets say i press up 3 times, 2 of those times it will go - and one tim e it MIGHT go +, seems random. Other times it will stay still and make a grinding noise. I am clueless here. Anyone got any ideas?
I got your point sir, it just makes a hum noise while press a Y button, been there hehe, im going to work now then Ill take all the config files, screenshots on how I set my CNC on the ports and pins etc. I`ll get back to you after 5:00pm
For some reason I cant PM you because your inbox is full, so I just post it here anyway
I went ahead and cleared it out, can only have 8 pm's at a time! hahah
I may be late to the party but did you look on the disk provided if there is a setup file? I don't have your machine, I have the 3020 but with my software CD I had a folder with different machine names on it. Inside was a file that when double clicked would configure the Mach3 software to set up the XYZ ports, motor speeds and also the STOP button. See if you have a folder like that, it might fix all your problems.
Unfortunetly mine did not come with a config file. But as an updatew, it has been determined after using 2 different wires, on 2 different computers, that my breakout board is dead. I am having them ship me a replacement.
eUpdate: Got a new VFD, i have no communication between the VFD and the pc. i am wondering if i need some sort of driver? Has anyone of you gotten on of these machines and actualy gotten it to work? I am still looking for help with this.
I have it working! ..mostly. User KH0UJ has taken a large amount of his time out of quite a few of his days to talk to me over google hangouts and help me to get it working. Without his help i would not have been able to get this machine to even make a noise. The X, Y, Z, and A are working very well, they jog at a nice speed. I have not optimized it to move at a very fast speed yet, but he taught me how to get them going and calibrated. The guy taught me WAY more about CNC and mach3 than i knew before. That all being said.. The man needs some kind of award for having to deal with me! haha.
I will be making a post right after this to go over my only remaining problem.
At the moment all but my spindle is working. Every time i try to start my spindle it goes full power. on the VFD the 24000rpm spindle is controled by 400hz. Every Hz seems to modify 60 RPM if my math is right, and the VFD isint lying to me. I have set the VFD D032 setting to 1 which refers to computer controle, and switched the knob to pc as per the instructions. The PC does in fact turn the spindle on, However.. It ramps to full speed and gives me an error of "PWM bumped to minimum setting"
Here are my current settings
http://i.imgur.com/ZGxOksa.png
The spindle does however work on manual.
Last edited by Ergelbak; 03-21-2017 at 02:26 PM. Reason: Posted before i ment too without fulll detail
Hi Ergelbak, you and I may become new friends. I have this exact control box with the 800w spindle. I'm on my 2nd control board, and have only had it running once with the spindle. There is a file that needs to be loaded into mach3, also depending on if you are running MS Vista you'll need yet another file added. I now get an error while trying to start up my spindle from the control box, E LU error code. So after a month with tech support, I get to start all over.
Oh, if you pm me, I can send you the files that the manufacturer sent me. The spindle settings are different than what yours say.
Almost there sir but one thing for sure though, once you are skillful enough on that machine, you will start eliminating things hehe, like limit switches? nah I dont need them, front spindle cover of the ball screws, you will take that out if it starts giving you problems of being stuck, stepper motor harness you will change that if you want optimum torque on it, spindle control over MACH 3 ---Manual mode hehehe, once you start tweaking it to it`s optimum movement speed the starting rotation of the spindle will get left behind because the movement of the XYZ are now quick enough to nose dive your bit on the material being machined sure thing you can manipulate it thru the codes though but with a time limit pressures you, you will start optimizing even the codes itself hahaha
