Looking for help with settings for Huanyang VFD (1.5kW 110V)
Results 1 to 6 of 6
Thread: Looking for help with settings for Huanyang VFD (1.5kW 110V)
    Feb 2012
    Default Looking for help with settings for Huanyang VFD (1.5kW 110V)
    Hi all.
    I had this VFD working great with my Chinese 6040 router when I used it last a few years ago. But recently I blew the dust off the router and the VFD settings seem to have been reset or otherwise forgotten.
    This is a Huanyang HY01D511B 110V 1.5kW VFD driving a 110V 800W spindle rated at 5A, 400Hz and 24000rpm.
    I have seen many postings for settings for Huanyang 220V VFD versions with different spindles, but none seem to be close enough of for me to figure out the necessary differences. It's been very frustrating since I knew the right settings a few years ago but I didn't record them anywhere. Lesson learned...
    Can anyone recommend the correct settings for the Pd variables?
    Any help would be greatly appreciated!
    Member mactec54's Avatar
    Jan 2005
    Default Re: Looking for help with settings for Huanyang VFD (1.5kW 110V)
    Quote Originally Posted by Qubert View Post
    Hi all.
    This is all you need, all the basic Parameter Settings are the same for all the 400Hz Spindles, just voltage and Amps that are different
    Don't do a Reset unless you have to, sometimes doing this affects the order of how the Parameters get set
    Huanyang Mactec54
    PD000=0 for Parameter unlock ( 1 ) for Parameter Lock
    PD001=0 (1 For Remote Control)
    PD002=0 ( 1 For 0-10v Terminal Control or Remote Trim Pot Control )
    ( J1 Also Needs to be set for Terminal Control )
    PD003=400
    PD004=400
    PD005=400
    PD007=20
    PD008=220 (120 If you have 120v VFD )
    PD009=15
    PD010=8
    PD011=120 ( 100 Minimum Setting with Quality VFD, 120 is Safe)
    PD13= 08 is for Factory reset, Only use this to set VFD to Factory Default Settings
    PD014 Acceleration=12 ( Adjust to suit)
    PD015 Deceleration=12 (Adjust to suit)
    ( PD15 is ignored IF PD26=1 Then the Spindle will Coast to a Stop)
    PD141=220 ( Motor Rated Voltage ) (120 for VFD Rated for 120v )
    PD142= ( Motor Max Amps)
    PD142=( 220vSet for your motor Amp Rating 2.2Kw Spindle 9 amp )
    PD142=( 220VSet for your motor Amp Rating 1.5Kw Spindle 7 amp )
    PD142=( 220v Set for your motor Amps Rating 800w Spindle 4 amps )
    PD142=( 120v Set for your motor Amp Rating 800w Spindle 7 amp )
    PD143=2 ( Motor Number of Poles)
    PD144=3000 (Max Motor RPM) =3,000= (24,000)
    PD70=0 ( This may need to be set to 1 if Control Voltage is 0-5v )
    PD72=400
    PD73=120 ( 100 Minimum Setting )
    Mactec54
    Feb 2012
    Thanks for the fast response!
    I'll try these tonight.
    Feb 2012
    Thanks mactec45! Works perfectly and I've now got it under RS485 control.
    One question though... The lowest spindle speed with these settings is 7200rpm. Is that correct?
    Jan 2005
    That is correct
    If you want to try it PD11=100 and PD73=100, this will give you 6000RPM which is the minimum speed you can run, but do this with caution, watch for a rise in temperature of the spindle when you run at this speed
    Mactec54
    Jun 2016
    If anyone else is having difficulty with a 110V HuanYang VFD, I have an article on how I integrated it on my website:
    Large CNC: Design and Construction
