Originally Posted by
aarggh
I've got the 6090B myself and couldn't be happier with it. Much better than the 6090A in my opinion, but to answer your question, the process of creating, loading and running the code is exactly the same as for other machines, but does the machine you're looking at come with NCStudio or is it wired ready for Mach3 as most of these come with NCStudio?
If it's ready for Mach3 then you'll have no more difficulty getting it setup than any other machine, in fact these machines are generally extremely well made with good drivers so it will likely be easier to configure than a lot of the cheaper Chinese units. There's a number of people on the forums here such as butterknife, (I think viroy as well?) and others who have setup their 6090 with Mach3 and could probably give you their xml config so your ready to go. But usually the seller will have the config for you to download or at least a doc with all the relevant settings.
In short, I wouldn't be the least bit concerned with getting it setup with Mach3, but I can guarantee you'll be very, very happy with the machine! They're the bees knees!
If your getting one I'd definitely be considering the B over the A version, in for a penny in for a pound I reckon.
cheers, Ian
