I'm back with another mod...
Flood coolant
And making some real chips!
I've been running this with the flood coolant for almost 3 months and it's been really awesome. Although I have a vice mounted in the pic I've been using a high density plastic spoil board setup using T-slot nuts and straps to hold down parts.
I decided to make a bow riser for my wife since she's been wanting a bow. So I went to the local metal supply and picked up a 1 1/4"x6"x9" slab of 6061 Al and this is what I came up with.... yeah a 1.25in thick of Al on a 3020!!!
Only 2 tools needed to make this bow handle!
1/4in 3 flute flat end with 45* helix from YG
1/8 2 flue ball nose with about 30* helix from Suncoast
The accuracy is mind blowing!
Latest recipe for 6061:***
CAD/CAM: Fusion 360
Cut Type: Adaptive, toroidal strategy
DOC: 3.5mm
Cutting Feed rate: 814mm/min.
Ramp Feed/Angle: 680mm/min @ 7degrees
Spindle RPM: 20,000
Flood Coolant: Jancy Slugger Water soluble cutting fluid
Key things I've found that make this 3020 a reliable and accurate machine:
1. Spindle motor mod
2. x-axis support guides
3. Adaptive machining strategy
4. 1/16th micro-stepping controller running @ 35k kernel speed on Mach3
