Newbie OmioCNC report - Page 107
Page 107 of 108 FirstFirst ... 75797104105106107108 LastLast
Results 2,121 to 2,140 of 2141
Thread: OmioCNC report
  1. #2121
    Member MichaelMassier's Avatar
    Aug 2020
    Unhappy Re: OmioCNC report
    Hi there, 1st post here:
    I received the OMIO X8-2200 5 days ago.
    Having some issues with OMIO technical support - don't know yet if it is due to bad handling (DHL) only or some other manufacturing deficiency.
    I'll come back with info as soon as the problem gets solved... or not.
    Attached Thumbnails Attached Thumbnails OmioCNC report-2-jpg
  2. #2122
    Member IsakAndersson's Avatar
    Oct 2018
    Default Re: OmioCNC report
    Hi all. I just got the Omio X8-2200L with 4-axis version AH60-XX80M-10. Everything seems to work fine so far, except the 4th axis. I'm getting a lot of rattling noise and it moves very slow. Also, when I enter "G0 A90" in MDI it goes to approximately 25 degrees instead.
    My settings.
    Motor Tuning:
    Steps per: 13.333
    Velocity: 600
    Acceleration: 200
    Step Pulse: 5
    Dir Pulse: 5
    Motor Outputs:
    Step Pin#: 8
    Dir Pin#: 9
    Dir Low: No
    Step Low: Yes
    Step Port: 1
    Dir Port: 1
    Edit: I also noticed a+ is in the counter-clockwise direction. Is this normal? I'm used to having it the other way round. Is there a setting to change this?
    Last edited by IsakAndersson; 08-13-2020 at 12:48 PM. Reason: Weird ASCII no workie.
  3. #2123
    Aug 2020
    Quote Originally Posted by MichaelMassier View Post
    I would appreciate any help and advice in sorting things out.
    OMIO does only:
    "We know our machine better than you"
    "Why did you disassembled it"
    "You can ship it back to China at your own expense"
    "The "problems" you think are normal assembly processes in production, but you don't have this ability , otherwise everyone can produce it."
    Here is a link to a video I made with the info I have until now.
  4. #2124
    Oct 2018
    Turns out I had the wrong manual (TH60-K6 instead of AH60-XX80M-10). I contacted Omio and got the right settings. Now it works!
  5. #2125
    Member Phani_avireddy's Avatar
    Nov 2019
    Hello guys great into here. I'm a newbie looking to buy an omio x-8. I have experience with 3d printers now looking to step into cnc. I heard about guys recieved their cnc with misaligned holed , binding rails etc etc. I heard a lot of good stuff too. My question is was any of those things a deal breaker. I'm willing to put some elbow grease if required.
  6. #2126
    Dec 2017
    Sweden
    I bought my Omio X8-2200L-USB three years ago and used it on daily basis for my work. Generally I'm satisfied with it but sometimes (but still seldom) it steps wrong so after a recommendation from dharmic here on the forum I decided to change the motion controller to a CNC Drive ABXX-E (Ethernet). I've made some progress in converting it but I'm not sure about the connection from the card to the spindle controller (the "Nowforever" white box). On the terminal one of the used connections says 12 V (or maybe 12 U) - does this mean it has to be fed with 12 volt from the ABXX-E?
    I have got how the wiring to the stepper drivers should be hooked up but I don't really get how the spindle driver should be connected to the ABXX-E. All documentation here, example wiring diagram is on page 28:
    https://www.cncdrive.com/downloads/AXBB_E_manual.pdf
    I would appreciate if someone can get me on the right track - or better, have done a similar modification.
  7. #2127
    Member Sterob's Avatar
    Jan 2007
    I don't use or have seen the ABXX-E but I do have a Nowforever VFD.
    The VFD needs to see a closed contact on ( usually ) x1 and Com ( with VFD paramter set ) so get a Start and a 0-10v speed signal on terminals on AIN1 and Com ( with VFD paramter set ) to se the speed.
    The 12V terminal is a 12v SUPPLY from the VFD , IF you need it. I suspect you won't but, keep it in mind.
  8. #2128
    Member dharmic's Avatar
    May 2015
    Quote Originally Posted by dynaflux View Post
    Dynalink, sorry I missed your message until just now - but @Sterob has it. The speed control is done with that 0-10V signal which should be coming from AO1 with the jumper set appropriately for 0-10V instead of 0-5V. Connect the analog COM on the VFD to the 5V0 out on the ABXX-E. The run pin on the VFD (X1 on my manual by default) gets connected to port O1, and the 24V0 input on the ABXX-E (or the 24V PSU input) should go to the VFD's digital input COM line.
    That should get you up and running - otherwise you might need to get in touch with the CNCDrive people.
    Good luck!
  9. #2129
    Sep 2016
    I hope this thread isn’t too old. I am having an issue with my spindle speed that I believe can be solved by changing the parameters in the VFD. I talked to OMIO’s tech support but they will only tell me what the parameters are supposed to be set to by default and won’t even tell me what the parameters do. I am measuring spindle speed with a laser tachometer.
    My VFD came with the below parameters and when I set MACH 3 to 24,000 RPM, the spindle would spin at 3000 RPM. It appears to be linear down to 0 RPM.
    P0-000: 1
    P0-001: 0
    P0-002: 2
    P0-003: 0
    P0-004: 50.00
    P0-007: 400.00
    P0-009: 8.00
    P0-010: 8.00
    P0-012: 400.00
    P0-024: 50.00
    I changed the VFD to the following parameters provided by OMIO:
    P0-000 = 1
    P0-001 = 0
    P0-002 = 2
    P0-003 = 2
    P0-004 = 400
    P0-007 = 400
    P0-009 = 8
    P0-010 = 8
    P0-012 = 400
    P0-024 = 400
    I now have the following results:
    MACH 3 settings vs. measured RPM:
    Setting : Actual (rpm)
    5000 : 575
    10000 : 8570
    15000 : 16200
    This is much closer but they are still not aligned. It appears that I might be able to align MACH 3 to the actual spindle speed by adjusting the VFD parameters.
    Is this possible? Which parameters do I change and by how much? What do the different parameters do?
    Thank you for taking the time to help me,
    -Tim
  10. #2130
    Member Pyronious's Avatar
    Nov 2019
    When you set the RPM to 24000 in Mach3, what does the display on the VFD show? It should display “400” Hz.
  11. #2131
    Sep 2016
    Quote Originally Posted by Pyronious;[URL="tel:2476816"
    2476816[/URL]]When you set the RPM to 24000 in Mach3, what does the display on the VFD show? It should display “400” Hz.
    It does display “400” Hz.
    I forgot to mention the spindle is brand new and I had the same issue with the old one.
  12. #2132
    Member jd479's Avatar
    Jul 2018
    Default Re: 4th axis problem
    Quote Originally Posted by jd479 View Post
    1st post to this forum.
    've really been helped with all the posts with my x8-2200. I've added a 0.5" aluminum stiffener plate to the bed, used zeeflyboy's example for self contained water cooling on the gantry and added some lexan shields on the side for safety and to help contain the dust. I've used the machine for about 2 years except for the 4th axis.
    Now to my problems:
    The 4th axis is at the stepper end of the bed running down the Y axis. I'm using an aspire rounding tool path at 75ipm. Intermittently the Y axis loses it's home and goes off one end or the other of the work during the cut. I started at 150ipm and the problem is a more regular, but still random so I cut the feed rate in half and that helped a lot, but occasionally it still has the issue. When the problem starts, it sounds like the stepper frequency goes way up for a moment and it loses position on the Y axis. This has led to a few broken bits.
    The problem appears whether the 4th axis is connected or not, and I can hear the freq change when air cutting with the spindle powered off. The g-code looks ok and many times it works for a while, and shows the problem at different line numbers. Only thing I've checked so far is the PS voltage. With the controller disconnected it sits at 42 volts, and doesn't seem adjustable. Don't know what it should be. I haven't connected a scope to it and don't know if I can capture any meaningful data since it is so intermittent.
    2nd weird issue is with the Z touch off plate. It works fine until I try to use it with any g-code loaded into mach3 (latest version). Touch off then goes to the plate as normal, and Z moves up to the home switch instead of stopping at the normal few mm above the plate. This happens every time, and I have to stop and restart mach3 with no g-code loaded to be able to use the touch plate again.
    It may be that the omio xml configuration file that was included with the machine is affecting this, but I'm both g-code and xml challenged, so would really like any suggestions the group can give.
    JD
    I replaced the spindle cable with a 4 wire to ensure spindle ground was physically grounded to the star grounding point on the control box rather than relying on grounding through the z bearings. Things are working well, but haven't tested the 4th axis again.
    Found the simple stupid problem with the Z touch plate. I installed mach3 and used the OMIO xml file for configuration which left the machine in metric. I'm in the US so use inch for my code. The post processor inserts a G20 at the beginning of the code, so I think the m930 macro
    FinalMove = GageH + 10
    Code "G0 Z" &FinalMove
    is telling mach3 to move up 10" rather than 10mm
    Changing from mm to inch in mach3 fixes the issue, but the motor tuning is way off.
    REQUEST: if anyone has successfully changed mach3 from mm to inch and adjusted the motor tuning for imperial, could you please reply to this with those values. I'd really appreciate the info.
    JD
  13. #2133
    Member Xaer's Avatar
    Jun 2022
    Hi all. It seems the interest, or at least the post frequency, is slowing on this thread, but here goes:
    I'm a complete noob in cnc, but i have a bit of 3d-printing experience and modifying that. Programmer by trade.
    I somewhat randomly got across a very, very lightly used o x8-2200l just half an hour drive from here. The machine is half-assembled (test driven supposedly working well) with an axbb-e. Supposed to be a year old. The asking price is 2500usd. Am I crazy to consider this? Are there now better machines, controller boards etc in this category, or is it still a good starting point to get into cnc machining? For comparison, the machine would set me back more than 4000 usd if bought new from China, with transport and taxes. Feedback greatly appreciated!
  14. #2134
    Jan 2007
    Quote Originally Posted by Xaer View Post
    I think that is a reasonable deal and a good place to start your cnc journey.
    Those machines have linear rails on all axis's which is good and the after market motion board is a good improvement e nt as well..
  15. #2135
    Jun 2022
    Quote Originally Posted by Sterob View Post
    Thanks a lot for your feedback. Is there like a obvious check list I should go through before buying it? Aside from the obvious gut feel of seeing how it looks for a non-savvy person?
  16. #2136
    Jan 2007
    Not really....Just go and see the machine. Get him to demo as much as he can and go from there.
    These machines are built to a price, but this one is miles ahead of where I started from a few years ago. Mine was a 6040 with round rails.
    They all need some fettling and mods to improve them. I had to fix a +1mm offset in the x ball screw on mine, but it ran nice after I fixed that....lol
    I fitted a Ethernet Smooth Stepper to mine and it made a huge improvement to its smoothness. also fitted HD connectors to the steppers as the baby ones fitted were getting warm! That was noticeable as well!
    The AXBB-E one the one you are looking at might be fine. I have no experience with them.
  17. #2137
    Jun 2022
    I will meet with him this Saturday, so we will see how it goes. Since it is not assembled entirely, I'm a bit worried that the curve to success is going to be a steep one.
  18. #2138
    Jan 2007
    Yes, the learning curve will be very steep, but if you work one problem at a time and persist, you should succeed.
    You will save alot of money and have a nice starting machine at the end.
  19. #2139
    Jun 2022
    So the guy called in sick the day before we were going to meet, so new chance this coming Saturday. Fingers crossed ????
  20. #2140
    Jun 2022
    Machine picked up and assembled! Yey! All axes seem to move smoothly, and I have connected the electronics to it, and the pc with UCCNC is connected to the axbb-e card successfully.
    Now, this is where I'm out of my depth, when it comes to configuring all limits and axes and steps, etc. So I wonder if there is someone that may want to share their settings or better yet, an uccnc profile? Thank you!
OmioCNC report
OmioCNC report
