"Any questions I might be able to help with on the Syntec 6MA perhaps I we can share or if anyone has any tips or tricks I'm always keen to learn"
Hi Lee, I hope this offer still stands after seven years :-)
I just purchased a used 2017 3 spindle machine with a 6MA control. I'm catching on to the process (while learning V Carve at the same time) but there's two issues I can't get around.
1) I'm told the TTO does not work for some unknown reason which may relate to issue 2
2) I can set Z for T1 using Offsest>workpiece>latch process and T1 works fine. But the instructions say to use Tool Wear Set >Tool Length to reference and set T2 and T3 to ZAb0. However, Z Ab never changes to 0. It remains the value I gave the respective T length.
Do you have any experience with an issue like this or can you direct me to someone who might?
Cheers
