You're g-code tells Mach3 what to do. You need to edit your g-code to cut outside the lines. What are you using for CAM?
trying to make Mach3 cut outside the line and not on it.
UCCNC 2017 Screenset
Im trying to make plastic gears for clocks, I have no idea about editing Gcode
Sorry, I worded that wrong.
You need to create your g-code to cut outside the lines.
Again, what are you using to create your g-code?
If y our working with .dxf files, you can open them in a CAD program, and offset the lines by the tool radius, and use the offset lines to create you g-code.
i use Mach3 and lazy cam, i also use coral draw and just started using Inkscape
