Originally Posted by
Qubert
I am new to CNC and would like to get a router mostly for wood and plastic, but that is stiff enough to do some light aluminum machining.
I have been looking at the Fireball V90 and Comet, but the V90 doesn't look very stiff, and the Comet is a bit more money than I'd like to spend. I'd like to stay under $2000 US.
While I am a newb when it comes to CNC, I am an engineer and I have a fairly good electronics and mechanical background.
Some questions for those of you with CNC 6040's:
1) Are you happy with your machine?
2) Is it suitable for a beginner to debug and learn on?
3) I'm in the US. Has anyone ordered a 110V version, or are you using a transformer? Can I simply run off of 220V @ 60hz?
4) Should I inquire about an upgrade from the standard 0.8kw spindle to a 1.5kw spindle?
5) And last but not least, who's a good supplier to order from?
Thanks!
