Need Help! Charter Oak IH6000 - runaway table
Results 1 to 3 of 3
Thread: Charter Oak IH6000 - runaway table
    Jan 2017
    Exclamation Charter Oak IH6000 - runaway table
    While doing some routing milling, suddenly my table went at full speed in the negative x axis until it hit the external stop. Turned it off, waited, rebooted, same thing. Driving it with Mach Three software, factory installed. When I launch software and reset, the second I try to move table in positive x, it kicks in to negative x movement, then shuts down immediately, because it is already at the stop. Need help isolating the problem. Software? Cabling? Controller?
    Nov 2003
    Illinois, U.S.
    Default Re: Charter Oak IH6000 - runaway table
    If servo machine. The first thing I would check is the encoder and or cabling for the x motor.
    Jun 2005
    You might want to disconnect the motor from the axis while you troubleshoot the issue. As vertcnc said if this is a servo system a bad encoder could send it seeking.
    Russ
