Y axis Ballscrew nuts screws NEED tightening
Results 1 to 3 of 3
Thread: Y axis Ballscrew nuts screws NEED tightening
    Mar 2013
    Default Y axis Ballscrew nuts screws NEED tightening
    My Y axis is sloppy and I found the screws that secure the ballscrew nut to the table are loose. I can get to the rear two that are right on the edge, Has anyone tightened all four?
    My mill is on a stand, on a pan, so I can not just go from underneath and gain access to them. I could punch a hole in the pan to access them but it appears that the "front" two are under/behind the ball screw itself.
    I am thinking to try and take the table off?
    Any clue on my best way to tackle this?
    Tony
    Mar 2013
    Default Re: Y axis Ballscrew nuts screws NEED tightening
    I have the mounting screws for the block on my mill. From the photo you can see there are two, counter sunk screws under/behind the thinner steel mounting collar.
    #1 I have not been able to mover it, I think it is locktite'd
    #2 If it does move, the screws threads are most likely greater than the threads to the block. Im thinking it would just lock itself up.
    Any suggestion would be great
    Attached Thumbnails Attached Thumbnails Y axis Ballscrew nuts screws  NEED tightening-ballscrew-nut-jpg
    Mar 2013
    I think this assy video might be what Im looking for to Disassemble it and tighten the two screws
    This might help someone else down the road.
