Acorn and Close loop steppers
Results 1 to 3 of 3
Thread: Acorn and Close loop steppers
    Sep 2017
    South Africa
    Default Acorn and Close loop steppers
    Dec 2009
    Default Re: Acorn and Close loop steppers
    Quote Originally Posted by Flashvac View Post
    Does the Acorn board support closed loop steppers
    Sorry, for such a late reply. You might post on the Centroid User forum Centroid Acorn CNC Controller - Centroid Community CNC Support Forum
    But yes it does as long the the stepper motor driver is closing the loop and takes step and direction signals. That is, the encoder from the stepper motor plugs/connects to its driver. Posting an example of which motor/driver you want to use is most helpful, otherwise we are guessing at what you want to use.
    Marty
    Member ger21's Avatar
    Mar 2003
    Shelby Township
    Which is the same as every other step/dir controller.
    UCCNC 2017 Screenset
