Hi Keith, I'm contemplating a used lathe with a fanuc control that has failed. the drives and servos checked out fine but fanuc recommended a control replacement. I noticed that the fanuc kits you show on the ajax website use the MPU11/GPIO4D and this uses the allin1dc. what are the advantages of one over the other? another question I have is for the spindle. this particular lathe uses a fanuc servo for the spindle as well. can the allin1dc drive the fanuc spindle, or would it need another servo drive?
thanks
Jim
Sent from my SM-G920W8 using Tapatalk
