Nice work!
I enjoyed your tin can method further down in the blog - pouring wax into the bottom of the can, set the wax pattern and then pour investment around it. I take it that the initial layer of wax is needed to allow you to open the can with a can opener?
I suppose you could achieve the same effect by using masking tape across the bottom of an open can (with both ends cut off).
LinkBack URL
About LinkBacks
