Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking > Casting Metals
Casting Metals Discuss casting metals here.
Old 08-27-2009, 09:39 AM
Inventthis's Avatar
Inventthis is on a distinguished road
Question Please help with Cupola plans
Does anybody know where I can find free cupola plans to melt iron?
I looked online without any luck.
Old 08-27-2009, 10:08 AM
acondit's Avatar
acondit is on a distinguished road
I don't know about free but if you google Lindsay Books they have some good books on building cupolas.
Alan
http://www.alansmachineworks.com
Old 08-27-2009, 10:11 AM
ErnieD is on a distinguished road
cupola
Try Lindsay's Publications. They have many helpful plans for the home shop "tinkerer". Just Google Lindsay's and you will find them.
ErnieD
Old 08-27-2009, 02:13 PM
rowbare is on a distinguished road
I googled "cupola furnace" and found these in the first few links:
http://www.backyardmetalcasting.com/cupola02.html
http://www.rockisland.com/~marshall/foundry.html oops not free...
Old 08-31-2009, 06:57 PM
paprjam's Avatar
paprjam is on a distinguished road
I have Marshall's book, it's excellent. The BYMC site's furnace didn't work very well and he hasn't posted any updates on it.
Cupolas are pretty simple, just a metal tube with a good refractory lining. I wouldn't recomend any homemade refractory or all you'll get done is patch.
Size depends on how much you want to tap, and how many people you have to help run it. If it's just you, then your probably limited to a 7 or 8 inch bore.
I'm planning one out of 3 five gallon metal buckets with about an 8 inch bore.
Fuel is the tricky part, if you can find a good source of coke I think that would be the best or real hardwood charcoal as a close second. Brickettes won't work and will clog up the whole thing with cinders from the binders they use.
You'll also need a pretty big blower. better to have too large than not enough.
For now, I'm melting small amounts of Iron in a crucible furnace. Sure messes up the crucible.
Old 09-02-2009, 03:50 PM
paprjam's Avatar
Here is a link to a very old table top cupola. I would suggest more safety equipment.
http://www.copperstarways.com/Downlo...laExcelent.pdf
Old 09-10-2009, 04:26 AM
Inventthis's Avatar
Thank you all for your replies and the useful links.
Cheers
Old 09-10-2009, 08:05 AM
paprjam's Avatar
We expect Photos and videos.
Old 01-29-2012, 05:48 PM
TrickyCNC is on a distinguished road
this is now a broken link
Old 02-02-2012, 11:16 AM
Rocco85 is on a distinguished road
Fortunately, it's been mirror on a few other locations, here's one of them: http://173.201.227.192/docs/Blacksmi...kshop_2004.pdf
  #11   Ban this user!
Old 02-02-2012, 12:43 PM
paprjam's Avatar
That's great, I thought I had the PDF saved but couldn't find it. I saved it now.
They are pretty simple to build. Get the tuyere height correct is the hardest part. Too high and the Iron will solidify before it comes out the tap hole. Too low and it gets hot and plugs up the tuyere or you don't get much metal. It depends on the diameter of the cupola.
Chastain has a formula for it, can't remember what it is right now.
  #12   Ban this user!
Old 02-02-2012, 01:50 PM
aluminum maintence free roof cupola woodman08 Gorilla CNC Machines 4 06-01-2009 08:55 PM
Project - Big F'n Cupola ajinjax CNC Wire Foam Cutter Machines 11 04-24-2009 10:03 PM
Cupola Zoinker Casting Metals 3 09-11-2007 04:03 AM
Is there at Kit or just the plans? GTGene JGRO Router Table Design 5 03-27-2007 07:52 PM
My plans c0rpse Open Source CNC Machine Designs 3 06-01-2006 02:42 PM
