Results 1 to 2 of 2
Thread: low presssure die casting quality issues- advice
    Feb 2006
    india
    hello,
    we cast plenty of parts in low pressure die casting and one of the common problems we face is inclusion/ oxide entrapment on the top face of the casting which is formed on the upper half of the die cavity. , we use mesh filters on the gate but problem is not eliminated.
    advice remedies
    thanks in advance
    rags
    Attached Thumbnails Attached Thumbnails low presssure die casting quality issues- advice-pc190033.jpg
    Apr 2009
    Are you sure it is inclusions/oxides in the metal? From the picture it looks like a gas problem. Are you using any means of de-gassing the metal prior to filling the die?
    Dan
  1. Need Help!- Small, Good Quality Lathe - Buying Advice Please?
    By archiebald in forum Mini Lathe
    Last Post: 10-22-2008, 03:11 AM
  2. My first casting
    By tool_man in forum Casting Metals
    Last Post: 03-29-2007, 12:28 AM
  3. Some advice needed on X-Axis belt issues.
    By kumaichi in forum Industrial Hobbies (Support forum)
    Last Post: 02-21-2007, 09:47 AM
  4. STL and casting
    By Jcadwell in forum General Metalwork Discussion
    Last Post: 05-15-2006, 05:01 PM
  5. aluminum casting advice needed
    By carbidecraters in forum Casting Metals
    Last Post: 07-04-2005, 11:04 PM
