Page 2 of 2 FirstFirst 12
Results 13 to 14 of 14
Thread: My Spin Caster Build
  1. #13
    Mar 2005
    For a 12" spincaster, the bottom plate is probably 12.25" diameter and the piston/clyinder @ 5 or 6". Maybe source your O ring and design around that? The O rings are probably about 3/16 - 1/4" thick.
    www.harryhamilldesigns.com
    CAD sculpting and services
  2. #14
    Registered SScnc's Avatar
    Jun 2008
    Thanks very much for that information Harry, I'm working on locating and making the components for pneumatic operation. In the meantime I did the three threaded rods and will use threaded knobs from Enco until I can switch over.
    Below are a few update pics showing the control panel with tach. I still need to label the controls. Thanks again to Joe S. for his coding work on the tach.
    Also I have the electric melting furnace built, just waiting on the infinite control to arrive but have fired it up and it seems to works very good. I'm ordering a zinc ingot today from budget casting supply and have to order the silicone from JBJ too. So I should be able to do the first test castings very soon.
    Attached Thumbnails Attached Thumbnails My Spin Caster Build-img_0862_small_.jpg   My Spin Caster Build-img_0863_small_.jpg   My Spin Caster Build-img_0864_small_.jpg   My Spin Caster Build-img_0868_small_.jpg
    My Spin Caster Build-img_0873_small_.jpg   My Spin Caster Build-img_0870_small_.jpg   My Spin Caster Build-img_0869_small_.jpg   My Spin Caster Build-img_0872_small_.jpg
  1. Motor Won't Spin
    By DeusExMachina in forum Hobbycnc (Products)
    Last Post: 12-10-2008, 07:23 PM
  2. Green sand caster needed in MN, Dakota, Iowa, WI area
    By carbidecraters in forum Casting Metals
    Last Post: 08-05-2008, 05:37 PM
  3. Need to spin something in the Z
    By originator in forum Mechanical Calculations/Engineering Design
    Last Post: 01-10-2007, 08:05 AM
  4. Hobby Metal Caster in Denver??
    By Stuff-Builder in forum Mentors & Apprentice Locator
    Last Post: 09-23-2005, 11:57 AM
  5. Why do we spin the screws?
    By Jcadwell in forum CNCzone Club House
    Last Post: 05-02-2004, 11:33 PM
