Results 1 to 2 of 2
Thread: New Castable Metal
    May 2008
    New Castable Metal
    We have developed a new steel that eliminates the need for heat treating by transforming to martensite at a very high temperature. So you can cast it in any shape, it transforms at a high temperature without distortion, and then it auto-tempers itself as it cools so that when you reach room temperature you have a thru-hardened, fully tempered martensitic microstructure having Rockwell Hardness of RC45. You can use it for near net shape molds and dies with complex cooling channels and uniform back-plane cavity thickness for uniform cooling etc. It is also very strong > 170 ksi yield, can be further hardened to RC60 and is very hot formable by rolling and/or forging. It is also very weldable and machinable. So it can be used virtually for most anything you want.
    Sep 2005
    Sound s fantastic ..do I understad correctly that this steel can be cast in sand yet treade like froged item? .is this steel available every where or is it a closely guarded secret cheers peter
  1. First cut in metal
    By sickpaint in forum Syil Products
    Last Post: 12-25-2007, 07:17 PM
  2. Spray or castable FOAM???
    By pointcloud in forum General Material Machining Solutions
    Last Post: 11-22-2007, 08:48 AM
  3. Replies: 7
    Last Post: 08-16-2007, 01:26 PM
  4. where do you get your metal?
    By annihilator in forum DIY CNC Router Table Machines
    Last Post: 11-24-2004, 05:28 PM
