Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking > Casting Metals
Casting Metals Discuss casting metals here.
Old 06-06-2008, 05:54 PM
KyleH2's Avatar
KyleH2 is on a distinguished road
Casting material to use for aluminum parts that end up being welded.
I was thinking I could cast aluminum into some thick walled tubing and then machine the ID and OD and make my parts rather than buying stock. (After baking at 300*F first). The parts are weld on aluminum flanges so finish and temper are not important. Nor are the tolerances real tight.
How much should I leave on the ID and OD for clean up turning? I was planning on making my pattern with a piece of steel pipe turned to the size I need for the pattern.
This would be done in my back yard and the parts are turned on a manual lathe in my garage.
Old 06-06-2008, 06:52 PM
youngjim is on a distinguished road
If you're going to make a pattern, allow 6% for shrinkage of the material itself; if you're going to be casting it at home, I'd leave a lot more because aluminum is pretty touchy to cast. Expect a lot of porosity too. Type 214 and 355 come up as good casting alloys, both with good machinability.
No time to do it right, plenty of time to do it twice.
Old 06-06-2008, 07:02 PM
KyleH2's Avatar
I believe the material I have access to is 356. The reason I am using it is it works out to be about .50-$1 per pound not counting preparation. (Paint removal and cutting into melt-able strips) And I can easily get it in about 22 pound blocks 7 days a week. Will probably use a plasma cutter to cut it and a sand blaster for paint removal.
Old 07-23-2008, 02:43 PM
Kipper's Avatar
Kipper is on a distinguished road
I made this a few weeks ago, It's around the 6" 150mm mark and I allowed 1.5% on the pattern and a 1° draft all over...I cast it in oil bonded sand.
It came out less than 0.005mm oversize=Acceptable
Printed by a Zcorp printer and I gave it a good bashing and it held together!
Oh the material was the same as you mention 356...AKA Scrap Soon to be cast in LM25 from bought in ingots.
Just a sample part for a customer.
Might be time for a new rug!
ID:	63599   Click image for larger version
ID:	63600   Click image for larger version
ID:	63601   Click image for larger version
Keith
What foam for aluminum casting? biomed_eng Casting Metals 10 03-13-2007 09:30 AM
Anodizing Welded Aluminum Deviant General Metalwork Discussion 9 10-17-2005 09:23 AM
aluminum casting advice needed carbidecraters Casting Metals 8 07-04-2005 10:04 PM
Casting material? ynneb Moldmaking 9 06-23-2005 11:29 AM
2 AL parts in need of casting mike_r Casting Metals 2 05-19-2005 04:09 PM
