sure. I have lots of experience in producing plaster molds and plaster mold castings. are you looking for advice on making the mold, or are you looking for a casting source?
Hi
Does any one have experiance of making plaster molds for parts like this????
Hi esscasting
I am looking for some information or journal or litrature which explains the process. I thought of making the mold out of plaster but now i am thinking to make it out DFS (dense fused silica) and heating it in a furnace. DFS because it has the properties required for my experiment.
I also thought of making the pattern out of ABS instead of wood.
well, without knowing too much detail about your project (part geometry, quantity and tooling life) and priorities (time vs $ invested vs metallurgy requirements), it's difficult for me to provide any advice. I'm not particularly familiar with DFS, but I'm under the impression that it is used to make a semi-permanent mold which it typically done for production quantities. Depending upon part shape complexity and size, this could result in significant greater investment in tooling compared to prototype/low-volume methods like traditional sand casting or plaster mold casting.
for information on a variety of casting processes, there are several books on Amazon that are fairly cheap, my guess is they are useful for the hobbyist only. If you're experiment is for a high precision, complex-shape then, I'd recommend starting at the American Foundrymen Society, www.afsinc.com. there is a searchable library in their technical section, but I'm sure you'll have to pay considerable $.
millions of parts like this are cast in green sand molds
In the words of the Toolman--If you didn't make it yourself, it's not really yours!
Remember- done beats perfect every time!!
Forget casting...what you need is a 36 axis cnc machine...Or go with what the previous poster recommends...Simple sand casting! :KISS:
Keith
Yup its a simple casting but I need a material which could give me unidirectional solidification and more over instumentations on this mold is much complex to use sand mold.
I dont have much data regarding Plaster mold its expansion coefficients, Thermal shock absorbtion capability etc...
use lost foam casting on this it gives very nice finnish and you could machine this from foam very easy
Navnav2006:
What are the basic dimensions? I can't read you drawing.
We investment cast A356 in-house all the time from patterns run on our own RP machines, but we have size limitations. How many do you need and what are the tolerances? Surface finish requirements? Do they need to be x-rayed or dye penetrant inspected? Need certs?
Bill Box, Mark Two Engineering, Inc.
well its better than sand casting, if you dip your pattern in plaster first and support it in loose sand
Try plaster of paris, mixed with equal parts of powdered pumice stone, which makes a find mold for casting fusible metals. Alternatively you may use dental plaster if economical.
