| Casting Metals Discuss casting metals here. |
Curious as to what it costs to have a domestic foundry make custom iron castings. Assuming the mold was already made (low complexity), and the quantity is something like 500lbs each x 100 pieces, what would be a typical price per pound of final product? Thanks. |
| One foundry that I know used to charge $1.00 a pound for material plus $100/hr for molding time. So your cost depends on how big the pattern is and how complex. However, 500 lbs. may be larger than their pour capacity. I know we had to send a pattern that was going to require a 1500 lb. pour to a larger foundry. A simple pattern mounted four up on a 14x16 pattern board cost me about $72 to have four boards made (16 pieces that weighed about 1 lb. each). Alan
__________________ http://www.alansmachineworks.com |
| Oops, lost track of this thread. Thanks Alan for the info. $1.00/lb is quite reasonable. And yes, I meant that the patterns are made. What constitutes a complex pattern? Lots of inside crevices and webbing? While on that topic, know of any good literature that describes proper casting design from an engineering standpoint? Which foundry did you get your stuff cast at? Seems like the hardest part of all this is finding the right one. |
Most of the books that I have are from the foundryman's point of view. What is doable and how to do it. The foundry that I was talking about is in Silverton, OR. There used to be a lot more around but over the last few years several have gone away. Alan
__________________ Andrew Abrams Marcellus Metalcasters, Inc. |
Don't forget, it was $1/pound plus $100/hr molding time. On small parts most of the charge is based on molding time. Also the last time I had parts cast was 3 or 4 years ago, they may well be charging more even for the iron now. Alan
| New vs old cast iron, new vs old steel ? | vroemm | Mechanical Calculations/Engineering Design | 18 | 11-08-2008 01:09 AM |
| welding cast iron | jimco | Welding, Brazing, Soldering, Sealing | 12 | 05-11-2007 02:35 PM |
| cast iron machining | drwc | General Metalwork Discussion | 3 | 01-15-2007 10:20 PM |
| Sources for raw Cast Iron. | DieGuy | General Material Machining Solutions | 4 | 12-26-2005 08:27 PM |
| Rust on Cast Iron | ChrisJ | General Metalwork Discussion | 10 | 05-18-2005 01:06 AM |
