Results 1 to 4 of 4
Thread: Aluminum and Stainless Steel Crucible
    Jan 2006
    I just got my basic aluminum foundry set up, and am using a stainless steel pot for a crucible. I have done several pours without any problems, but seem to get some slag that stays in the crucible after pouring out the aluminum, and it won't come out. The slag doesn't seem to be causing any problems, as I just leave it in, and remelt the next batch, but I would like to find a way to get rid of this stuff so it doesn't contaminate the metal further.
    I just read some threads about stainless steel reacting to the aluminum, and am wondering if I should switch to another type of crucible. I have a heavy steel crucible, but it seems like it will take more energy to heat up, and maybe add a different type of contaminate to the aluminum. I know I should probably be using a ceramic crucible, but right now I am not set up with the proper lifting tools for one. What are your thoughts and experiences with metal crucibles for aluminum, and slag control? Thanks.
    Feb 2006
    any steel crucibel (ss or other) will be slowly eaten by the Al. Crucibels are replacement items. Iron in Al is not good, makes it brittle. You have to decide what cost to bear.
    In the words of the Toolman--If you didn't make it yourself, it's not really yours!
    Remember- done beats perfect every time!!
    Registered metalworkz's Avatar
    Oct 2006
    Modesto, CA U.S.A.
    Hi Rico,
    Perhaps you could use a ceramic wash on the SST crucible which I believe will leave a protective layer on the crucible. Maybe this could be implemented temporarily until you can get a ceramic crucible? I use cast iron crucibles for aluminum melting when contamination is not a factor. I think for a lot of uses the amount of contamination will not be readily evident nor result in a defective casting, unless a specific grade is required.
    Regards,
    Wes
    Regards,
    Wes
    Feb 2006
    I have been using steel crucibles for aluminum for over 2 years now.Doesn't seem to cause any problems.While the crucible is red hot,scrape the sides and bottom.Works well for me.I have not used any type of coating but,ITC makes a ceramic coating for metal.A little expensive though.
  1. Stainless Steel / Aluminum Cut and Rolled
    By ukchris in forum Employment Opportunity
    Last Post: 01-18-2007, 09:09 AM
  2. Steel or Stainless
    By tool_man in forum Casting Metals
    Last Post: 10-29-2006, 06:46 AM
  3. Stainless Or Steel
    By 69owb in forum Mechanical Calculations/Engineering Design
    Last Post: 10-03-2006, 02:43 PM
  4. Stainless Steel ?
    By Depoman in forum General Metalwork Discussion
    Last Post: 01-12-2005, 06:40 AM
  5. Is stainless steel
    By CNCadmin in forum Hard and High Speed Machining
    Last Post: 10-17-2003, 09:19 AM
