Results 1 to 9 of 9
Thread: One off aluminum casting needed (Georgia)
    Registered mwood3's Avatar
    Jun 2008
    Anyone around Atlanta (or North Ga) interested in doing a lathe bed cast in Aluminum (think 7x benchtop lathe size) right now im interested in just a proto type but if it works out and I can get some interst I may look at some light production. PM me if you are interested in some work and have the capability. I can provide a pattern or we can discuss your prefered method.
    thanks
    Mwood
    http://www.g0704.blogspot.com/
    Jul 2007
    Have you considered casting it yourself in Epoxy Granite? It is about the same density as aluminum but has much better damping characteristics.
    bob
    Jun 2008
    Quote Originally Posted by rowbare View Post
    bob
    I have not considered this option, sounds like it would not be very resistant to daily shop abuse...I have considered constructing the base from steel tube and filling it with E/G to dampen and add weight.
    I have a thread going over in the benchtop forum, here is the link
    http://www.cnczone.com/forums/mini_l...ear_rails.html
    Right now im trying to get relative prices on each option. I would love to have the base cast in Iron but am thinking the cost would be too high to justify for this project, I resorted to Al. casting due to the high number of DIY home shops casting Al. hopefully they would be easier to work with and less costly than a "real foundry".
    Jun 2008
    Ok 71 views and no takers...can anyone at least point me in the right direction? I have contacted several foundries with no reply... Im sure this is not an appealing job to the big foundries but shurely there is someone out there that caters to this type of work? I guess if I cant find anyone to take it on I will construct the lathe out of steel tube and fill with E/G...
    Mar 2010
    To aid you in your search for a foundry, seek out other people in your area who are in the market for specialty castings, they might be able point you in the right direction. In my case, we were directed to a fairly large family owned foundry through a local marine outfitter who occasionally has antique hardware reproduced there. We were given a tour of the foundry by the owner and he was very willing to work with us to meet our needs. Good luck.
    May 2004
    Uhhh...Since you are going to have to do final machining to a casting anyway, why not start with a weldment (welded assembly)?
    http://www.kirkcon.com/
    Jun 2008
    Quote Originally Posted by txcncman View Post
    This option has been considered already, review my link to see the thread about my lathe project. I posted here in the casting section mainly to get info about a casting as another option.
    Jul 2008
    Cast lathe bed
    mwood3,
    To be honest cast Al for a lathe bed is a dreadful choice (sorry but there is no other way to put it). Apart from softness the main problem with Al is that it has absolutley no ability to damp out vibrations. resonance and hence chatter would be big problems. If you are serious about going down this road consider getting the casting made in A8 Mg alloy. This is the most common Mg alloy sand cast and you should be able to find a foundry willing to give it a go for a price. (Price will be steep I would reckon) Mg has excellent vibration damping -better than grey iron and it machines way way better than just about anything else. Some manufactures of large machine tools use Mg castings because of this and to reduce weight which with big (I do mean BIG) machines can become unmanagable.
    Martin
    Old foundrymen never die they just dross off
    Oct 2005
    Considering the low cost of aluminium plate you could use a slab of 25mm plate of a good quality like 6061 T651 and if vibration is an issue then glue or sandwich another slab of granite or epoxy granite, you can buy both reasonably cheaply cut to size as kitchen counter tops (check in the yellow pages).
    1. Problems Casting Aluminum
      By Burningleon in forum Casting Metals
      Last Post: 10-18-2011, 06:46 AM
    2. Whos Casting in North Georgia???
      By pointcloud in forum Casting Metals
      Last Post: 06-29-2008, 08:11 AM
    3. Several DIY casting questions... Lost Wax & Aluminum?
      By Sporqster in forum Casting Metals
      Last Post: 09-30-2007, 11:29 PM
    4. What foam for aluminum casting?
      By biomed_eng in forum Casting Metals
      Last Post: 03-13-2007, 10:30 AM
    5. aluminum casting advice needed
      By carbidecraters in forum Casting Metals
      Last Post: 07-04-2005, 11:04 PM
