Have you actually tried casting with the oil bond sand?
What grade of aluminum are you using to cast with? A grade with a
high silicon content will flow easily and fill thin voids quite well.
As you mentioned feed with risers where required.
Try and keep the metal temp below 800 Deg C and degas before you pour.
I have cast long thin fan blades around 2mm thick with no real dramas.
Cam
LinkBack URL
About LinkBacks
