Results 1 to 2 of 2
Thread: sand cores
    Jun 2006
    CANADA
    sand cores
    I am looking for a place to find information on and purchase coatings for sand cores to help make them harder and a bit easier to handle. Right now all i have is a CO2 binder but i need to handle the cores a bit and hand rub the edges to put a slight radius on them. Years ago we had something we brushed on the cores that made them alot harder but like all things i threw out the empty container without writing down the name.
    Oct 2007
    Core wash
    Kirby,
    Find a local foundry supply company and walk in with
    some examples of your work. A box of donuts helps.
    Tell them what you want to do and most likely you
    will walk out an hour later with a bunch of goodies and
    some new friends. If there are no local supply houses,
    then one of the casting forums on Yahoo with members in Canada
    will be glad to help with Canadian foundry supply houses
    that will ship.
    regards,
    Jim
  1. Newbie- Drawing 3D foam wing cores for RC airplanes V23
    By bchristal in forum BobCad-Cam
    Last Post: 04-25-2011, 01:23 PM
  2. Need Help!- Removing pattern from sand
    By Biggermens in forum Casting Metals
    Last Post: 02-20-2011, 08:06 PM
  3. Using Anviloy for cores
    By 9566317 in forum Moldmaking
    Last Post: 04-09-2008, 08:35 PM
  4. Baking Soda Cores for Aluminum Casting
    By dang in forum Moldmaking
    Last Post: 01-21-2008, 06:04 PM
  5. need more sand strength
    By BobM3 in forum Casting Metals
    Last Post: 08-12-2007, 11:45 AM
