Cement should work OK for a pattern. You'll have to seal it up with some paint so the surface won't stick to the sand. It may be a little heavy. I've used wood and bondo(2 part auto patch material). I seal it with a good high gloss paint, usually oil base but I don't know if that makes a difference.
LinkBack URL
About LinkBacks
