Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking > Casting Metals
Casting Metals Discuss casting metals here.
  #13
Old 01-24-2007, 06:19 PM
*Registered*
evildrome is on a distinguished road
Originally Posted by LUCKY13 View Post
LOL, no takers on that question hu. Thats the best looking casting I have seen from a small shop & I wander what it takes to get this good of a result?
Jess
20 years experience and some very nice equipment would be my guess.
If you wanted to work your way up to something like this you should start small, like with motorcycle heads or somesuch.
Cheers,
Wilson.
  #14   Ban this user!
Old 01-25-2007, 05:39 AM
LUCKY13 is on a distinguished road
Oh yea, I wouldnt expect to pulling this off from the get go. But I would like to achive casting my own Head. Starting with a small scale of the real part is something I though about. If I can get it right on a head that is 1/5 scale then it wouldnt be as bad to take it up to the real thing. Could probably get the srinkage figured out even at scale. But working with this level of pattarns & molds would be good before I even began to atempt something like this. Even at small scale it would probably take a wail to figure out the proccess to get just right.
A few things I have been noticing is the ones that use good ingots & sand & all the other goodies that go along with it seem to have a lot better results than you see most achive. Even on simple parts. This plus the little things that make a big differance in the proccess apears to be half the battle.
Ofcourse that is the way it is with all skills, the little things that is not noticed by the average eye is what makes the diff.
Jess
Old 01-25-2007, 06:05 AM
*Registered*
Jess,
You should definitely start small & work your way up.
The good equipment is an emergent property of experience. The good guys have the good gear because they have experience to know what to buy (and how to use it).
Experience is the key, not equipment. You can cast pistons by digging the right shape of hole in the dirt of your own backyard.
If you're just starting buy 'The complete handbook of Sand Casting' by C.W. Ammen (ISBN 0-8306-1043-X ). It is the beginners casting bible. I've read it a dozen times. Read it first & then when you start to cast & mould you'll see the real wisdom in the book.
Here's how I started:
http://www.wilsonlogan.com/Sfurnace01.htm
Cheers,
Wilson.
Casting Engine Parts Cnc Wana bee Jet Engines and Ram Jets 20 06-20-2011 06:02 PM
2 AL parts in need of casting mike_r Casting Metals 2 05-19-2005 04:09 PM
How close can I space THK rails? bgolash DIY-CNC Router Table Machines 7 12-30-2004 11:13 PM
A guide to permanent mold casting. Splint Casting Metals 7 11-28-2004 05:36 PM
Lost Foam Casting foamcutter Casting Metals 26 01-18-2004 03:20 AM
