Results 1 to 3 of 3
Thread: Gold Flake
    Feb 2010
    Gold Flake
    I tested what I thought was a sizable gold flake on the stove element. Initially it curled slightly under the heat and when it cooled the flake smeared between my finger tips. Does anyone know if perhaps this was not actually gold or was the reaction normal?
    Apr 2004
    Oakland CA USA
    That doesn't sound like gold to me
    Gold doesn't melt at stovetop temperatures, and even if it did, it wouldn't be affected by rubbing it between your fingers (unless it was liquid at the time, in which case you'd notice...)
    It sounds like you may have a piece of mica - that can shine a bit like gold, and it will delaminate when rubbed. Check it out with a magnifying glass; you might see lots of little platelets.
    Is there some reason you thought you had a piece of gold? Was it a piece of jewelry, or did someone sell it to you as a "gold nugget"?
    Andrew Werby
    www.unitedartworks.com
    Feb 2010
    I've started gold panning as a hobby and found what I thought might be a few flakes in some black sand along a river bank.
    Thanks for your reply. I'll investigate mica.
  1. Membership Cost and Features
    By CNCadmin in forum CNCzone.com FAQ
    Last Post: 12-26-2011, 10:54 PM
  2. GOLD AND SILVER
    By nikhil1300 in forum Mass finishing equipment/media/stratigies
    Last Post: 05-27-2010, 02:57 AM
  3. Taig z-axis leadscrew oil showing metal flake
    By MechanoMan in forum Taig Mills & Lathes
    Last Post: 04-26-2009, 08:27 PM
  4. Engraving into gold
    By matulo in forum General Laser Engraving & Cutting Machine Discussion
    Last Post: 10-21-2007, 05:32 PM
  5. Gold Chrome?
    By Smackre in forum Metal Finishing and Plating
    Last Post: 07-18-2007, 06:18 PM
