Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Carken Products (Deskam, DeskCNC etc)
Carken Products (Deskam, DeskCNC etc) Sub-Forums: Deskam, DeskCNC, DeskArt
Old 06-19-2003, 06:52 PM
Jon D is on a distinguished road
Mold making with Deskcam
I have been using DESKkam for about 6 months now.
I have been using the mold making capabilities but have been having a few problems. I intend to make female fiberglass molds directly in particle board thus avoiding the work of making plugs by hand etc.
I draw the solid model of my part in SOlidworks and then i export it as a .STL file. I use maximum detail in the export options.
However when i run the part there are often small mistakes in the tool paths.
Does anybody have any experinces with this?
Jon
Old 01-18-2005, 11:07 AM
CNCadmin's Avatar
Site Owner
CNCadmin has disabled reputation
anyone, i'd like to know myself.
Thank You,
Paul G
Site Owner-Webmaster-
Administrator
www.rfqwork.com
www.cnczone.com
www.welderzone.com
Old 02-08-2007, 04:41 PM
Gold Member
imserv is on a distinguished road
There are no mistakes. The model is interpolated at intervals "along" the X and or Y axis. You set the intervals. If you set the sampling interval too large, you will not sample the surface enough to create a realistic final part. This is great for roughing when you leave ample finish stock, but not too good for finishing. Vertical side walls will appear to have angles.
For finishing, use a sampling distance equal to the finish tolerance you want to hold. ie .001 inch in X and maybe .010 in Y. Note this will create larger files when finishing, but that is the desired result when you want an accurate machined surface.
Fred Smith - IMService
http://www.imsrv.com
Any mold maker around? kanankeban General Metal Working Machines 35 01-24-2012 10:56 AM
Making money with CNC Johnuk CNCzone Club House 26 12-13-2009 11:46 AM
BT30 taper spindle for mold making grantmi1 Hard and High Speed Machining 5 02-28-2006 03:41 AM
Beginner moldmaking questions fastturbovet Moldmaking 17 06-23-2005 04:38 PM
Welcome to the mold making forum. CNCadmin Moldmaking 0 07-07-2003 12:22 PM
