Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Carken Products (Deskam, DeskCNC etc)
Carken Products (Deskam, DeskCNC etc) Sub-Forums: Deskam, DeskCNC, DeskArt
Old 12-12-2009, 11:50 PM
antonzedd is on a distinguished road
Exclamation 3 axis dual drive, drift problem!!!
I got an aluminum profile (rails) 3 axis dual drive cnc (x2 motors on x). I'm getting about an 1/2" of drift on one of the sides, can't figure this out? Measure both sides, turn on controller enter DeskCNC load up a test file like smallsquare.nc and after I run it it seems fine?
I measure it and the drift starts out by being over 1 or 2mm on one side? Anybody know what this problem could be? Here is a link to the cnc I've got and all the parts I have:
http://www.pdjinc.com
http://www.pdjinc.com/parts.html
Any help would be appreciated, thanks.
Old 12-13-2009, 06:49 AM
Tweakie's Avatar
Tweakie is on a distinguished road
It's a long shot but it could be a noise issue.
Check your grounding and earth connections.
Tweakie.
CNC is only limited by our imagination.
Old 12-13-2009, 11:21 PM
Interesting...
I was thinking more along the lines of a bad driver? I've checked all the drivers
seems as though the Left X motor is not holding enough torque, plus there's a weird high pitch faint squeal only on that motor. Its definitely the driver. CRAP!!
Delays, delays, delays!
Old 02-28-2010, 03:40 AM
altonj2008 is on a distinguished road
Hi Anton, I'm Alton. I must say that I have always admired the machines on pdjinc. Your welcome pdj. They are clearly no nonsense and simple. And nice looking. I did notice though, that the wires that they sell are not shielded. I bought a used cnc router with Deskcnc and it has the same type wires. The wires are not shielded. This may be the cause. I am losing steps and basically having the same issue as you. As for you, I would think that pdjinc should be able to help you with this matter. Though, they may refer you to Deskcnc. If you solve your problem, I would be greatful if you could share it with me. And likewise, if I solve mine, I will do the same. I have tested my machine slowly and thoroughly and still losing steps. It runs very smooth. I added the line PULSEWIDTH=20 to the Controller section of the config file. This helped a little. Your settings may or may not allow this setting. I would recommend reading further about this at http://www.imsrv.com/discus/messages...tml?1113032192 and http://www.imsrv.com/discus/messages...tml?1135809262. My next step will be shielding all of the cables and grounding the machine frame and control box enclosure. Why take chances? Best of luck. Alton
Old 02-28-2010, 03:45 AM
Anton, I feel silly. I did not see your last post from 12-13-2009 before I replied. Anyway, if you or anyone else has any suggestions for me, I will be grateful. Thanks
Problem- Fadal 5th Axis Drift Problem LaysMachinist Fadal 1 11-16-2009 10:08 PM
Dual Drive on Long Axis? rweatherly JGRO Router Table Design 17 11-30-2008 01:21 AM
Need Help!- Solsylva Dual Lead Screw Table - Suddent Belt Drift Causing Issues mlammert DIY-CNC Router Table Machines 4 07-08-2008 05:08 PM
Simple, 3 Axes with Dual Drive/Motor (per axis), hardware splitter drive Interface. kreutz Stepper Motors and Drives 3 07-03-2008 06:57 PM
Z axis drift IainLGrant Benchtop Machines 1 03-12-2006 07:56 AM
