Results 1 to 6 of 6
Thread: Help G-code No Good
    Feb 2005
    Help G-code No Good
    hello im trying too system out for my roughter deskcnc and sheetcam/mach2
    i made a small dxf and genrated g-code on both.im curently using ezcnc and mach5when i load the g code i shows the part withen a bunch of circals that sround it?? both system codes did this??ive tryed evey post procesor and same rezolt?any help and also mach5 and ezcnc come up with the same thing.the dxf is 2d and does have holes in the part to be contured?
    Mar 2003
    Shelby Twp, MI....USA
    Check your I,J mode. It sound like it's absolute and needs to be incremental.
    Feb 2005
    ok but wher j or i
    ok thx for answer but ive look threw the program up and down and dont see any thing that stats abs or inc wher my i find this setting?? thx chris
    Mar 2003
    I don't use it, so couldn't tell you.
    Mar 2003
    Post some of your code and explain where you are creating it.
    Are you generating the program in DeskCNC?
    Fred Smith - IMService
    http://www.cadcamcadcam.com
    Registered HomeCNC's Avatar
    Mar 2003
    Ger21 is correct. This has happened with my Mach 2 software as well. I had code that I ran before fine. I did an upgrade of Mach 2 to a newer version and the code had large circles all around the part. Somehow Mach 2 had changed it's setting from Inc. to Abs. You must look through the setup screens to find where to change this. I can't remember where and I'm not at a Mach 2 computer now.
    Jeff Davis (HomeCNC)
    http://www.homecnc.info
    1. looking for g code 3d from bobcadcam or simmilar for indexer lpt v5 with g code soft
      By troyswood in forum Ability Systems - LPT Indexer and G-Code
      Last Post: 12-24-2006, 10:21 PM
    2. Jogging Suprise ? A good one !!
      By murphy625 in forum CamSoft Products
      Last Post: 10-18-2005, 01:01 PM
    3. parametric programming
      By Karl_T in forum CamSoft Products
      Last Post: 05-24-2005, 03:58 PM
    4. Please help find good CNC...
      By dino-new in forum General Metalwork Discussion
      Last Post: 01-13-2005, 06:24 AM
    5. Getting The Most Out of CNCzone's Posting Features
      By CNCadmin in forum CNCzone.com FAQ
      Last Post: 03-02-2003, 12:08 AM
