Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Carken Products (Deskam, DeskCNC etc)
Carken Products (Deskam, DeskCNC etc) Sub-Forums: Deskam, DeskCNC, DeskArt
Old 03-11-2005, 09:45 AM
cncmage is on a distinguished road
Angry Feed Rate uncontrollable?
I just finished my first cnc machine using the hobby cnc board and am running Deskams NC software and using some files created in artcam. The machine works great at max speed of 43in/min. I just tried slowing the speed way down to 2in/min to prepare cutting aluminum but I noticed i cant seem to alter the speed at all.
My g-code is providing the commands F2.0 for 2in/min feed rate but it seems like the hobby cnc board is not listening to them.
Funny thing is that I thought I had been changing the speed ever so slightly for the last week to fine tune my cutting but now makes me think i was not changing the speed at all, lol.
Any ideas?
Thanks,
CNCmage
Old 03-11-2005, 10:05 AM
WP1 WP1 is offline
WP1 is on a distinguished road
The HobbyCNC board has nothing to do with the feed rate. All it does is act on the step and direction signals generated by the software to drive the steppers.
If the feedrate is not changing it is a software issue. I can't tell you there though since I've only used EMC and Mach2.
Pete C.
Old 03-11-2005, 11:25 AM
ger21's Avatar
Are you using the Dos Desk NC? The website says something about jogging at maximum feedrate. I'm wondering if it doesn't support F words in the g-code? Did you try slowing it down with the slow button on the screen?
Old 03-11-2005, 12:10 PM
I tried slowing it with the buttons and it does seem to control plunge rate speed fine but not feed rate.
It also seems to only execute the F2.0 command on the line of the actual g-code line it inhabits. All the rest of the g-code lines after it seem to run at max feed rate.
Old 03-11-2005, 12:32 PM
ger21's Avatar
Try it with F2 on every line and see if it works.
Old 03-11-2005, 12:38 PM
joecnc2006's Avatar
www.joescnc.com
joecnc2006 is on a distinguished road
i thought when you set up your toolpath in art cam it askes for feed rate? what did you set your motor tunning at in your cam program?
Old 03-11-2005, 01:20 PM
ger21's Avatar
You can specify a feedrate in your CAM program, but you probably need to configure the post to put an F on every line. IF the post is configurable.
Old 03-11-2005, 02:09 PM
Eureka, I got it!
My default start velocity in Desknc was set at 31.5in/min and I was trying to cut at a feed rate of 2in/min so all the cuts were starting out way too fast and not able to slow down fast enough since I was trying to cut small circles in aluminum.
Anyway I got it now
Thanks guys,
CNCMage
fanuc o-t feed rate help joe1970 G-Code Programing 17 08-29-2009 12:49 PM
Need Bridgeport EZ-Track G-Codes to build post soweebee Bridgeport and Hardinge Mills 13 01-28-2006 02:10 AM
Advice needed for Mill Feed Rate raytor Benchtop Machines 4 03-25-2005 02:11 PM
Feed rate question studysession General Metal Working Machines 6 10-30-2004 02:00 PM
How can I up my feed rate ? ynneb DIY-CNC Router Table Machines 7 07-12-2004 10:40 PM
