Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Carken Products (Deskam, DeskCNC etc)
Carken Products (Deskam, DeskCNC etc) Sub-Forums: Deskam, DeskCNC, DeskArt
Old 02-18-2005, 06:13 AM
kpkale is on a distinguished road
Post Connecting a Controller Board
I had some problem related to connecting the stepper motors to the controller board.
Can someone give me a solution on how i can connect the motors to the board.
Secondly, can the 2nd generation board work with servo motors.
Old 02-18-2005, 07:31 AM
ger21's Avatar
The motors don't connect to the DeskCNC board. The DeskCNC board sends step and direction signal to motor drives, which can be either stepper or servo drives.
Old 05-02-2005, 01:30 AM
happytriger2000's Avatar
happytriger2000 is on a distinguished road
Can anyone explain the 'out I/0', 'Encoder', and 'in I/O', of the controller board?
thx
cs chang
Old 05-02-2005, 01:35 AM
Controller setup...open pdf
Old 05-21-2005, 09:02 AM
Gold Member
imserv is on a distinguished road
out I/O has the output connections. 7 relays and a PWM spindle speed control line.
Encoder is for the input of quadrature signals from an incremental encoder. Used for spindle synchronization in lathe threading or for manual pulse generator.
in I/O has the input connections for 4 home switches, limit/probe, e-stop, feed hold, and cycle start.
Fred Smith - IMService
http://www.cadcamcadcam.com
Old 07-29-2007, 05:39 AM
Paraprop is on a distinguished road
what is the cycle start input meant for ?
I could not yet make out from any documentation, what the cycle start input on the 2nd, gen. DeskCNC controller board is for except to download a new firmware. Any additonal usage during CNC operation ?
Dan
Old 07-29-2007, 09:59 AM
Gold Member
Cycle start is enabled on the Controller menu.
http://www.cadcamcadcam.com/hobby
Old 07-29-2007, 10:16 AM
cycle start / cam lobe
Fred Thanks a lot for your reply.
How does it react ?
does it have to be a connection to gnd. or +5V to start ?
just on a pulse from a push button or does the switch have to be closed for the entire cycle ?
Would appreciate If you could also have a look at another thread I just started today about cam lobe scanning on a 4th. axis.
Thanks in advance
Paraprop
One controller board does it all? Hack General Electronics Discussion 4 03-07-2006 04:51 AM
Open Source CNC Controller Specification gregmary DIY-CNC Router Table Machines 28 12-04-2005 10:58 PM
Does anyone know of a controller board for synchronized stepper motors Yellowbeard Stepper Motors and Drives 2 04-04-2005 12:06 AM
Looking for controller board for synchronized stepper motors Yellowbeard General Electronics Discussion 0 04-02-2005 09:50 AM
Controller board location smitty Benchtop Machines 12 04-02-2003 11:40 PM
