Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Carken Products (Deskam, DeskCNC etc)
Carken Products (Deskam, DeskCNC etc) Sub-Forums: Deskam, DeskCNC, DeskArt
Old 11-16-2008, 04:59 PM
bradyfb is on a distinguished road
Unhappy Confused with the pocketing command
I have attached a pic of what I'm trying to do; I want to pocket between the teeth of the sprocket and the large inner circle and the center circle is the bore. I do not understand how the pocket command works. Appreaciate any help. Thanks Brady
Name:	sprocket copy.jpg‎
Old 11-17-2008, 08:29 PM
wmgeorge is on a distinguished road
I am not a wiz kid, but the attached file was set to pocket .5 inches deep with a .125 mill cutter at 30 ipm, between the inside of the teeth and the large circle. It also will do the center bore , but I figure you could stop it when it got that far....
If I remembered what I did, I think I Declared the teeth as a Boundary and the center circle ended up being the island. Trial and error sometimes works for me!
I tried to upload the DNC file but it did not allow it to be done?? I could email to you as an attachment if needed.
Old 11-18-2008, 10:37 AM
timmydabull is on a distinguished road
you will need to pick both chains the tooth chain and the outer diameter circle chain.
chain the tooth profile to the outside,chain the outer circle to the inside.
if that doesnt work try using a contour toolpath instead using the same chaining method.
tim
2007 Haas TMP-1 Microscribe MX-5 Mastercam X4 Mill Level 3 Surfaces,Solids Seagate 2 tb hard drive AMD 64x2 8gig ram windows ultimate 7 64bit Geoforce 8800 GTX
Old 11-18-2008, 11:38 AM
tim
Tim, I thought he wanted to Pocket out the area between the inside of the teeth and outside of the larger circle like I have posted above? Looks like gear wheel driven from the inside with a smaller gear to turn a shaft of some sort.
He is using DeskCNC like I am... BG
Need help with pocketing! wdp67 BobCad-Cam 4 01-18-2008 03:41 PM
help with pocketing on MCX genexis Mastercam 9 06-29-2007 10:35 AM
pocketing signIT DIY-CNC Router Table Machines 7 06-06-2006 09:04 AM
Pocketing CNCadmin GRZ Software- MeshCAM 5 05-11-2006 08:44 PM
Pocketing dneisler BobCad-Cam 4 12-18-2005 10:57 PM
