Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Carken Products (Deskam, DeskCNC etc)
Carken Products (Deskam, DeskCNC etc) Sub-Forums: Deskam, DeskCNC, DeskArt
Old 08-14-2004, 12:35 AM
CNCadmin's Avatar
Site Owner
CNCadmin has disabled reputation
Post processor questions
OK, I'm starting to use deskcnc, what post processor do I use if i'm using deskam and or yeager?
Thank You,
Paul G
Site Owner-Webmaster-
Administrator
www.rfqwork.com
www.cnczone.com
www.welderzone.com
Old 08-14-2004, 12:38 AM
CNCadmin's Avatar
Site Owner
right now when I try to run a file I get a "unknown word starting at r on line 1" error
Thank You,
Paul G
Administrator
www.rfqwork.com
www.cnczone.com
www.welderzone.com
Old 08-16-2004, 05:01 PM
Kookaburra's Avatar
Moderator
Kookaburra is on a distinguished road
Paul,
A good one to use is ISO G-CODE. There are a few ISO posts ie: modal and non modal but try the one that comes with the install that just reads ISO_GCODE as its file name, if you are still having problems, send me a copy of your posted file and I will help you fix the problem.
"A Helicopter Hovers Above The Ground, Kind Of Like A Brick Doesn't"
Greetings From Down Under
Dave Drain
Akela Australia Pty. Ltd.
Old 08-16-2004, 05:44 PM
CNCadmin's Avatar
Site Owner
Their is no z codes being produced, so I have to use the post processor and add it manually.
Thank You,
Paul G
Administrator
www.rfqwork.com
www.cnczone.com
www.welderzone.com
Emco Compact 5 PC...have ???? Double G Mini Lathe 42 08-22-2010 07:26 PM
Upgrading control hardware - Emco eDudlik General CNC (Mill and Lathe) Control Software (NC) 21 12-08-2009 01:52 AM
v2xt post jrrhotrod Post Processors for MC 25 12-10-2008 06:20 PM
post processor help jrrhotrod Post Processor Files 8 01-14-2005 04:45 PM
One more little bump in the ProtoTrak post Shadowfaxx Post Processors for MC 1 01-04-2005 11:10 PM
