Results 1 to 2 of 2
Thread: Tool Start position
    Oct 2005
    Tool Start position
    Evnin all!
    Not posted before, bought an X3 with CNCTeknix controller a while back an have been having teething troubles - nothing unusual in that I'll bet!
    Simple questions
    I have a DXF file imported into DeskCNC that has a boundary with three circles inside it. On import it is centred on the origin of the grid. I move it to the origin and rotate it to a more sensible orientation.
    Why can I not then change the machining order, and what does the additional number beside the machining sequence number mean?
    And
    How do I set the tool commencement position to be the origin of the grid rather than a point on the last machined entity? THis is so that when I put a block of aluminium on the bed to commence machining I just position the tool at the bottom left corner of the block, and the tool will simply commence from there tather than racing off somewhere else to start machining.
    I hope I have explained myself fully - DXF file attached if it will help!
    Attached Files Attached Files
    Feb 2008
    sweden
    try p 4077
  1. tool carousel position problem
    By Greg 24 in forum Haas Mills
    Last Post: 10-19-2009, 04:44 PM
  2. Chinese scales to position the tool
    By Robin Hewitt in forum Benchtop Machines
    Last Post: 01-13-2009, 05:00 AM
  3. Reversing turret tool position
    By motter71 in forum G-Code Programing
    Last Post: 09-25-2007, 09:57 PM
  4. System variable for tool in ready position
    By Dana099 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 07-20-2007, 04:30 PM
  5. Tool position indicator
    By Jalex in forum Machine Problems, Solutions , Wireless DNC, serial port
    Last Post: 06-24-2006, 02:25 PM
