Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Carken Products (Deskam, DeskCNC etc)
Carken Products (Deskam, DeskCNC etc) Sub-Forums: Deskam, DeskCNC, DeskArt
Old 08-10-2007, 11:51 PM
Paraprop is on a distinguished road
Homing the 4th Rotary Axis "A"
My 4th Axis which is the A rotary, is now operational.
Given that the DeskCNC controller board allows for an "A" home input, I have provided it with an optical Omron switch to set Home on it. This will be very usefull to position my camshafts correctly.
However, now, I can't find out how to home it from the DeskCNC control screen. Any prompt advise would be appreciated.
Thanks,
Daniel.
Old 08-19-2007, 03:37 AM
I guess there is no button for Homing in DeskCNC screen.
However I managed to do it as a G code instruction in the MDI field
G30 A xx Fxx
Old 04-14-2008, 09:28 AM
Barry_ward's Avatar
Barry_ward is on a distinguished road
Keep up the good work
Para
I looked at the post about cams and was disappointed that everyone was so negative. I beleive that you can make your own cam machiine and learn along the way. You have the "what it takes" and "get 'er done" attitude that is really what cnczone is all about, not naysayers....
"Nothing in the world can take the place of persistence"
best regards,
Barry
my projects:
http://www.barryfish.com
Old 04-15-2008, 04:22 AM
Thanks for the supporting words.
Barry,
thanks for your suportive posting.
AS of now I have not implemented the setup but I have made most of the components required.
My main difficulty is to convert digitized cam lobe data into Gcode.
To digitize, I am using Performancetrends.com's cam tester setup.
Daniel.
Old 04-15-2008, 06:01 AM
Barry_ward's Avatar
g code generation
What form is the data in?
It should be "relatively" easy to get it into a format where a small program could generate the g code.
Or am I missing something?
Also to get rid of the steps that "that negative guy" was complaining about you could likely use a program that supported beizer splines and smoothing.
You are just going to spin the A axis and run you grinder with the Z, correct?
To me the "impossible" part will be keeping the wheel accurate.
I'm guessing that you will have to do 1 or more roughing grinds, then the final machining.
(PS I'm not a grinder, just a do-er)
"From the confidence that comes from ignorance, I proceed"
best regards,
Barry
PS on the good side, as the wheel wears, your cam will err on the over size side, which it seems would be better that being undersized. ("but I'm not a grinder")
my projects:
"low end" HF Spindle or "high end" router for about $1000? biomed_eng DIY-CNC Router Table Machines 14 01-06-2012 01:15 AM
BattleAxe "aka" Ball and Chain "aka" the wife. ZipSnipe CNCzone Club House 48 05-18-2008 10:53 AM
Has anyone looked at the "JET" or "Shop Fox" manual machines? boosted General Metal Working Machines 12 03-04-2007 10:33 PM
Calculating "steps per unit" for rotary axis? Beezer Mach Software (ArtSoft software) 2 11-28-2004 04:31 PM
Add "View New Posts" to "Main Menu" Mr.Chips Forum Questions or Problems 4 04-21-2004 11:54 PM
